[mapguide-users] Trouble with rendering service
monegodj MonegoDJ at cdm.com
Mon Dec 3 11:00:44 EST 2007
Thanks. I tried iterating over the byte reader like this, but found that it
would sometimes produce "stripey" images. Following Joe's suggestion, I used
the MgByteSink to save the image to disk, which works pretty reliably.
Kenneth, GEOGRAF A/S wrote:
> I have not used this for a while, as I found it borderline useless with
> the reader complications.
> As I recall, you cannot exhaust the MgByteReader by a single call.
> You must itterate over the reader, and read 8K blocks for each itteration.
> As I wrote, you should be able to find working code by searhing the posts.
> If you find it, the Code Wiki is at:
> http://trac.osgeo.org/mapguide/wiki/CodeSamples
> Regards, Kenneth, GEOGRAF A/S
View this message in context: http://www.nabble.com/Trouble-with-rendering-service-tf4899291s16610.html#a14132757
