[mapguide-users] Not much luck with ogr or postgis on Ubuntu
Jason Birch
Jason.Birch at nanaimo.ca
Fri Dec 7 10:15:13 EST 2007
I have PostgreSQL installed on my test server, so I can't be sure if it's libpq that is making the difference. I am able to get past Test Connection, but get an error saving the resource. I believe that this may bave been because I was connecting to a non-PostGIS schema though.
I still plan to start a VM from scratch with absolutely nothing extra installed. The problem with this one is that I installed and uninstalled a lot of packages testing things for the MapGuide compile.
Jason
From: mapguide-users-bounces at lists.osgeo.org on behalf of Jo Cook
Sent: Fri 2007-12-07 1:05 AM
To: mapguide-users at lists.osgeo.org
Subject: RE: [mapguide-users] Not much luck with ogr or postgis on Ubuntu
Hi Jason,
That removes the error when I run ldd -r libPostGISProviders.so, but I still
can't load the library when I use mapguide studio or when I try the "test
connection" option in the webtier tests.
I will try rebuilding with that library in place and see what happens...
I take it that's worked OK for you?
Jo
JasonBirch wrote:
> Jo,
> Can you try the following, and see if the PostGIS provider works for
> you?
> sudo apt-get install libpq-dev
> Thanks,
> Jason
> -----Original Message-----
> From: Jo Cook
> Ubuntu
> I made the change, rebuilt the whole fdo stack (including updating from
> the
> svn) and it didn't seem to make any difference. When I run ldd -r
> libPostGISProviders.so I still get the same error.
> mapguide-users mailing list
View this message in context: http://www.nabble.com/RE%3A-Not-much-luck-with-ogr-or-postgis-on-%09Ubuntu-tf4924763s16610.html#a14209174
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide-users/attachments/20071207/299358ec/attachment.bin
