[mapguide-users] Building SHP on Linux
Greg Boone greg.boone at autodesk.com
Mon Feb 12 14:02:24 EST 2007
What is your value for <install directory>?
This value should be the root location where your FDO open-source code
is extracted and built. The SHP provider needs to find the relevant FDO
and Third-party headers and libraries built in this location. If you
have not built FDO using the steps in the README file, then you will be
experiencing difficulties building any provider.
Greg
  _____
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Chris
Gountanis
Sent: Monday, February 12, 2007 2:00 PM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] Building SHP on Linux
I was trying to do teh SHP provider seperately since that was the only
one not built. I had to do:
export FDO=<install directory>/Fdo
export FDOUTILITIES=<install directory>/Utilities
export FDOTHIRDPARTY=<install directory>/Thirdparty
I will being trying that as soon as I can.
I am on Freenet IRC #mapguide if anyone wants to talk Linux. If I can't
get this stuff working on Linux by Tuesday I am not sure how much more I
will be trouble shooting.
Chris
	-----Original Message-----
	From: mapguide-users-bounces at lists.osgeo.org on behalf of Greg
Boone
	Sent: Mon 2/12/2007 12:44 PM
	Cc:
	What process did you use to build FDO and its dependant
Third-party
	files? Did you follow the build steps located in the FDO
OpenSource
	OpenSourceBuild__README.txt file?
	Greg
Chris
	Gountanis
	Sent: Monday, February 12, 2007 1:15 PM
	To: mapguide-users at lists.osgeo.org
	Subject: [mapguide-users] Building SHP on Linux
	configure: error: The default FDO API path  is not a valid
directory.
	Please use the custom option
	What is the simple fix for this? I have all the other FDO files
built in
	/usr/local/fdo.../lib seems SHP was skipped. Any idea cause I am
really
	burnt out on tweaking configure files :)
	Chris
	mapguide-users mailing list
	http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070212/22174b47/attachment.html
