[mapguide-users] Building SHP on Linux
Bruce Dechant bruce.dechant at autodesk.com
Mon Feb 12 16:59:46 EST 2007
Can you check to ensure that the folders referenced in the
serverconfig.ini file exist?
I have highlighted them below:
LibraryRepositoryPath              = Repositories/Library/
LibraryResourceDataFilePath   = Repositories/Library/DataFiles/
SessionRepositoryPath             = Repositories/Session/
SessionResourceDataFilePath  = Repositories/Session/DataFiles/
SiteRepositoryPath                   = Repositories/Site/
Thanks,
Bruce
  _____
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Chris
Gountanis
Sent: February 12, 2007 1:33 PM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] Building SHP on Linux
Now I am on the Server make test command and it seems hung on this:
(1165|3026582016) MgServiceManager::Initialize()
(1165|3026582016) MgServiceManager::Initialize() - Creating Resource
Service.
Repositories/Site: No such file or directory
Repositories/Site/__db.001: No such file or directory
(1165|3026582016) An exception occurred in DB component.
DbEnv::open: No such file or directory
Exception occurred in method MgDbEnvironment.MgDbEnvironment at line 98
in file DbEnvironment.cpp
(1165|3026582016) MgServer::~MgServer()
(1165|3026582016) MgSessionCache::~MgSessionCache()
(1165|3026582016) MgServiceManager::~MgServiceManager()
(1165|3026582016) Releasing Resource Service. Reference Count: 1
(1165|3026582016) Resource Service released.
(1165|3026582016) MgServerManager::~MgServerManager()
Any ideas?
Chris
	-----Original Message-----
	From: mapguide-users-bounces at lists.osgeo.org on behalf of Greg
Boone
	Sent: Mon 2/12/2007 1:02 PM
	Cc:
	What is your value for <install directory>?
	This value should be the root location where your FDO
open-source code is extracted and built. The SHP provider needs to find
the relevant FDO and Third-party headers and libraries built in this
location. If you have not built FDO using the steps in the README file,
then you will be experiencing difficulties building any provider.
	Greg
  _____
Gountanis
	Sent: Monday, February 12, 2007 2:00 PM
	I was trying to do teh SHP provider seperately since that was
the only one not built. I had to do:
	export FDO=<install directory>/Fdo
	export FDOUTILITIES=<install directory>/Utilities
	export FDOTHIRDPARTY=<install directory>/Thirdparty
	I will being trying that as soon as I can.
	I am on Freenet IRC #mapguide if anyone wants to talk Linux. If
I can't get this stuff working on Linux by Tuesday I am not sure how
much more I will be trouble shooting.
	Chris
of Greg Boone
		Sent: Mon 2/12/2007 12:44 PM
		Cc:
		What process did you use to build FDO and its dependant
Third-party
		files? Did you follow the build steps located in the FDO
OpenSource
		OpenSourceBuild__README.txt file?
		Greg
Behalf Of Chris
		Gountanis
		Sent: Monday, February 12, 2007 1:15 PM
		To: mapguide-users at lists.osgeo.org
		Subject: [mapguide-users] Building SHP on Linux
		configure: error: The default FDO API path  is not a
valid directory.
		Please use the custom option
		What is the simple fix for this? I have all the other
FDO files built in
		/usr/local/fdo.../lib seems SHP was skipped. Any idea
cause I am really
		burnt out on tweaking configure files :)
		Chris
		mapguide-users mailing list
		http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070212/70ae3dbe/attachment.html
