[mapguide-users] King.Oracle FDO Provider ORA-12705 error
Haris Kurtagic
haris at sl-king.com
Thu Feb 22 08:02:24 EST 2007
I came on this issue in situation where it was installed stanadard
Oracle client previously (as usually described on www if you search for
that error).
Solution was to rename or delete that nls_lang entry ( as suggested on
www).
If you still have standard Oracle client installed on machine you can
also use King.oracle for standard Oracle client version.
Haris
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jon Vincent
Sent: 20. februar 2007 22:45
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] King.Oracle FDO Provider ORA-12705 error
I am attempting to get up and running with the King.Oracle FDO provider
but I am having some trouble making the connection in MapGuide Studio.
I am using the 0.4.4 version, and I have the latest version of Studio
installed(1.0.0.17804), but when i attempt to make a connection I get
the error: ORA-12705: Cannot access NLS data files or invalid
environment specified.
I have taken a look at the HKEY_LOCAL_MACHINE\Software\Oracle\NLS_LANG
setting and I have tried renaming, and deleting it. I added it back in
and changed the value to AMERICAN which is the setting for nls_language
for my database. I can't find any other information about this and I
was hoping someone else may have some other suggestions.
Finally I'm running Oracle 9i (9.2.0.1.0).
Any suggestions would be appreciated.
Thanks
Jon
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070222/17cf27f4/attachment-0001.html
