[mapguide-users] ArcSDE to SDF or SDF3
Knight, Gregory Gregory.Knight.bra at cityofboston.gov
Thu Feb 22 15:22:26 EST 2007
You might try going from SDE to SHP - which will preserve your
attributes.  You can convert to SDF if you so desire when you load the
features into MGOS.
Greg
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of nicholda
Sent: Thursday, February 22, 2007 10:36 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] ArcSDE to SDF or SDF3
I am new to Mapguide Opensource and I'm trying to convert ArcSDE 9.1
data to
SDF for use in Mapguide Opensource.  I am using the FME workbench for
the
translation.  I am able to translate spatial data to SDF but have been
unable to translate any of the attribute data from ArcSDE 9.1.  I am not
able to use a direct connect to SDE as an end user since I don't have
admin
rights to the server.  Does anyone know of a way to perform this
translation
that I am attemting.  Any suggestions are wlecome.  Thanks.
nicholda
View this message in context:
http://www.nabble.com/ArcSDE-to-SDF-or-SDF3-tf3273416s16610.html#a910206
2
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
