[mapguide-users] ArcSDE to SDF or SDF3
Brad Nesom
kidsmake6 at msn.com
Thu Feb 22 22:12:41 EST 2007
Trying to understand why you are not using the sdeFDO
Ifyou just want to use fme because of how cool it is that is ok too. In my
latest version you just have to drill down a bit further to get to the
attributes then you want to match them up to a seperate table on the other
side. choose your favorite weapon. if you go to ms access the odbc is
probably going to be easiest be sure to export the same key field into both.
Reply-To: MapGuide Users Mail List <mapguide-users at lists.osgeo.org>
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] ArcSDE to SDF or SDF3
Date: Thu, 22 Feb 2007 07:35:35 -0800 (PST)
I am new to Mapguide Opensource and I'm trying to convert ArcSDE 9.1 data to
SDF for use in Mapguide Opensource. I am using the FME workbench for the
translation. I am able to translate spatial data to SDF but have been
unable to translate any of the attribute data from ArcSDE 9.1. I am not
able to use a direct connect to SDE as an end user since I don't have admin
rights to the server. Does anyone know of a way to perform this translation
that I am attemting. Any suggestions are wlecome. Thanks.
nicholda
View this message in context:
http://www.nabble.com/ArcSDE-to-SDF-or-SDF3-tf3273416s16610.html#a9102062
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
_________________________________________________________________
The average US Credit Score is 675. The cost to see yours: $0 by Experian.
http://www.freecreditreport.com/pm/default.aspx?sc=660600&bcd=EMAILFOOTERAVERAGE
