[mapguide-users] ArcSDE to SDF or SDF3
Knight, Gregory
Gregory.Knight.bra at cityofboston.gov
Thu Feb 22 22:47:12 EST 2007
This is a good point... and one Id overlooked in my response. I did experiment a bit with the sdeFDO provider and wasnt exactly thrilled with the performance. If your data sets arent too large, then the FDO provider may be OK. It seems that MGOS performs best with SDF data sources. If you find performance with SDE is not acceptable, you may prefer the conversion route. Personally, I think FME is cool.. ;) I belive they recently joined the open source community in some respect - so it will be interesting to see how their involvement affects this community. In any case, you certainly have options.
From: mapguide-users-bounces at lists.osgeo.org on behalf of Brad Nesom
Sent: Thu 2/22/2007 10:12 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] ArcSDE to SDF or SDF3
Trying to understand why you are not using the sdeFDO
Ifyou just want to use fme because of how cool it is that is ok too. In my
latest version you just have to drill down a bit further to get to the
attributes then you want to match them up to a seperate table on the other
side. choose your favorite weapon. if you go to ms access the odbc is
probably going to be easiest be sure to export the same key field into both.
Reply-To: MapGuide Users Mail List <mapguide-users at lists.osgeo.org>
Date: Thu, 22 Feb 2007 07:35:35 -0800 (PST)
I am new to Mapguide Opensource and I'm trying to convert ArcSDE 9.1 data to
SDF for use in Mapguide Opensource. I am using the FME workbench for the
translation. I am able to translate spatial data to SDF but have been
unable to translate any of the attribute data from ArcSDE 9.1. I am not
able to use a direct connect to SDE as an end user since I don't have admin
rights to the server. Does anyone know of a way to perform this translation
that I am attemting. Any suggestions are wlecome. Thanks.
nicholda
View this message in context:
http://www.nabble.com/ArcSDE-to-SDF-or-SDF3-tf3273416s16610.html#a9102062
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
_________________________________________________________________
The average US Credit Score is 675. The cost to see yours: $0 by Experian.
http://www.freecreditreport.com/pm/default.aspx?sc=660600&bcd=EMAILFOOTERAVERAGE
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070222/0a9b2c16/attachment.html
