[mapguide-users] Guestion about speedup mapguide,
diferent domainname to mapagent.fcgi.
Traian Stanev
traian.stanev at autodesk.com
Wed Feb 28 15:04:34 EST 2007
Another theory that I am thinking about at the moment... what if one
makes a virtual web server folder out of the directory where tiles are
generated? This way tile pngs will be directly accessible via http
without going through either MapGuide's server or web components, at
the cost of certain assumptions (one base layer group only in the map,
no changes to the map will be detected).
Traian
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: Wednesday, February 28, 2007 2:59 PM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] Guestion about speedup mapguide,diferent
That's true (for IE too) but it's not really something that we want to
force our users to do.
Primarily, this is because it's over most of my clients' heads.
Secondarily, if we have them do this then we are pushing our accepted
increase in this standard out to all of the other sites that this user
visits.
Maciek, it might be worth setting this value locally to see if you do
get an apparent performance increase. Theorerically you should, but
your current choke point might be something like map composition on the
server.
Jason
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Traian
Stanev
Sent: Wednesday, February 28, 2007 11:52
I think the number of connections is configurable in Firefox. Navigate
to about:config and search for the
"network.http.max-persistent-connections-per-server" setting. It
defaults to 2, but can be bumped up. Not sure if it would actually work,
since I haven't verified it.
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
