[mapguide-users] Guestion about speedup mapguide,
diferent domainname to mapagent.fcgi.
Traian Stanev
traian.stanev at autodesk.com
Wed Feb 28 20:35:49 EST 2007
Yes, the problem of the tiles not necessarily being on the same machine as the web server is one of the limitations/assumptions that I had in mind also. But then I decided that this can be worked around by using a file system mount from the web server to the server where the tiles are. I've seen a similar thing done on Linux/Apache, not sure if Windows could handle such a setup.
Traian
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org on behalf of Paul Spencer
Sent: Wed 2/28/2007 8:00 PM
To: MapGuide Users Mail List
Cc:
Subject: Re: [mapguide-users] Guestion about speedup mapguide,diferent domainname to mapagent.fcgi.
I'll weigh in here :)
There was a recent thread on the ka-map list that is relevant to this
discussion. The poster claimed (I didn't verify it, but it seems
correct) that tile sources in google maps all point to a variety of
server names like:
m0.google.com
m1.google.com
m2.google.com
m3.google.com
and that each of these resolves to the same IP. This is being done
to provide more simultaneous connections than a default configuration
of a browser would make - and it works very well.
The poster also provided a patch for ka-Map that implemented a simple
round-robin server picker from an array of available servers for the
tile code. He claimed substantial improvement in apparent tile
loading speed because more tiles loaded simultaneously.
I am going to be implementing his patch in ka-Map (in a slightly
different way, but the same concept) because I need this for a
current client. I can report back on our success.
On a side note, OpenLayers already has the capability to specify an
array of servers as a tile source for a layer.
Finally, we've been looking closely at optimizing kaMap performance
for our client. Part of this has involved reorganizing how the tiles
are physically cached on disk to avoid problems with having too many
entries per directory. The other part was using the web server
directly to serve tiles. This means the client is aware of the
server cache structure and the cache is directly exposed through the
web server. A 404 error handler is used to trigger tile generation
when the cache does not contain a particular set of tiles.
Also, we switched from Apache to lighttpd as it is quite a bit faster
at serving files. There are also other web servers that are faster
than Apache.
One of the problems I see with MapGuide's tile caching mechanism is
that the tiles are not stored at the web tier, but rather at the
server. This implies that you must invoke some process in addition
to the web server and wait for the transfer between the server and
the web tier, even if they are on the same machine. This would be a
very difficult problem to solve in MapGuide, though, because the
architecture allows you to set up multiple web tiers and multiple
servers in the back end - I don't envy Bob this particular problem :)
Cheers
Paul
On 28-Feb-07, at 6:52 PM, Jason Birch wrote:
> Hi Trevor,
> There are two points here:
> - If the tiles were served directly from disk by apache (or IIS), you
> will likely better performance than through the tileservice, primarily
> because there will be less CPU overhead. However, the recent changes
> there (caching maps, etc).
> - From the client level, they only have two pipes to receive those
> tiles
> through, so even if you're serving 100 tiles per second, the client is
> only going to be able to download two at a time. They have to pull
> down
> all of the HTML and JS code through the same pipes, so initial load
> time
> can be a killer at high resolution (more tiles to fill the screen).
> On a somewhat-related note, TileCache looks interesting:
> http://labs.metacarta.com/wms-c/
> Jason
> From: Trevor Wekel
> Subject: RE: [mapguide-users] Guestion about speedup mapguide,diferent
> I don't know how much network latency and bandwidth affect tile
> serving
> speeds. However, I have had very good tile serving performance over a
> LAN with recent builds of MapGuide. I have seen tile serving
> speeds in
> excess of 100 tiles per second over a gigabit ethernet link with
> current
> hardware (Pentium D 820).
> It would also be worthwhile to monitor CPU usage on the server while
> tiles are being served. I suspect the bottleneck is CPU and not
> network
> latency or bandwidth.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
|Paul Spencer pspencer at dmsolutions.ca |
|Chief Technology Officer |
|DM Solutions Group Inc http://www.dmsolutions.ca/ |
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070228/84a066cd/attachment-0001.html
