[mapguide-users] MapGuide Open Source or MapServer
Paul Spencer
pspencer at dmsolutions.ca
Mon Jan 29 19:19:54 EST 2007
As someone who has used both (and is actively working with both), I
believe you will get the most mileage out of concentrating on the
toolkit you will build the application with. As it stands,
MapGuide's application framework is not the most suitable for the
kind of application you are describing. It could easily be used to
build this application, but the framework would necessitate a server-
side solution involving redrawing at least one layer from the server
for every update. This is not necessarily a bad thing, but if you
want a smooth client-side experience, using a javascript toolkit like
OpenLayers (http://www.openlayers.org/) or ka-Map (http://ka-
map.maptools.org/) will give you a google-like experience and allow
you to plot and move client-side markers in real-time - something
that the MapGuide application framework doesn't quite support yet.
OpenLayers and ka-Map are client APIs that use map tiles (MapGuide
can do tiles too) to provide the map context, but provide a
javascript API for plotting points/lines/polygons and creating
interactive popups etc - just like google maps. ka-Map has been
built on top of MapServer directly and employs a reasonably popular
tile caching mechanism that improves performance and map quality
dramatically. OpenLayers can use tiles from a wide variety of
sources, including MapServer directly and from ka-Map's tile caching
mechanism. In addition, there is a new tile caching mechanism that
is supported by OpenLayers that is built on a proposed standard for
making WMS requests cacheable. At this point, it would be difficult
to say which is superior ... I think they are just different,
although in the long term the standards-based approach would be more
desirable to most people.
I have built several applications using ka-Map that do essentially
what you are looking for. I know that the same thing has been done
with OpenLayers as well, although I haven't personally done it.
Disclaimer: I am the creator of ka-Map and am also a developer on the
OpenLayers team ;) In the future, the two apis will be coming closer
together and, hopefully, merging. My recommendation is that you
should start with OpenLayers.
Cheers
Paul
On 29-Jan-07, at 6:44 PM, Bruce Dechant wrote:
> Jim,
> I’m not sure there is a direct comparison between the two, but I
> would highly recommend that you try MapGuide as it is very easy to
> use.
> The response you get here might be biased since you are asking this
> in a “MapGuide” mailing list. J
> Perhaps others who have used both could comment.
> Thanks,
> Bruce
> From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-
> bounces at lists.osgeo.org] On Behalf Of Jim Canniff
> Sent: January 29, 2007 9:02 AM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] MapGuide Open Source or MapServer
> Hi all,
> I'm looking for some advice on which GIS package to use for a
> project I am about to start. I'm a junior level Java programmer and
> have not used any GIS software at all. I've been asked to determine
> which software would suit our needs. We are developing an
> application which will display real-time information on multiple
> layers over a GIS moving map. In it's simplest form, we would like
> a flight track updating every 1-3 seconds, with additional objects,
> such as wind barbs, plotted as a layer over the flight track. The
> application will run from a Linux server (Debian distro), but must
> be available within a standard web browser (IE, Firefox, Safari).
> In my brief searching I've noticed much press regarding MapGuide
> Open Source and MapServer. However, I've been unable to locate a
> discussion comparing the two.
> Any advice you might have will be greatly appreciated. Thank you.
> mapguide-users mailing list
|Paul Spencer pspencer at dmsolutions.ca |
|Chief Technology Officer |
|DM Solutions Group Inc http://www.dmsolutions.ca/ |
