[mapguide-users] MapGuide Open Source Instalation issues
jamesdudden jamesdudden at blueyonder.co.uk
Sun Jul 22 08:26:01 EDT 2007
Hi
My setup is slightly different to yours (I am running XP with MGOS 1.1, PHP
and IIS 5.1) but i encountered the same problem.
You have to make sure the Mapguide Server is running by going to the
services panel, (under Control Panel/Performance and
Maintenance/Administrative Tools/Services) then under mapguide if the
services isn't started, start it. If it is try re-starting it.
Hope this helps
Regards
James Dudden
dorin wrote:
> Hi,
> I try to install MapGuide Open Source on Windows 2000 Professional. I
> followed the PDF InstallConfigure MgOpenSourceonWindows from osgeo.org.
> I installed MapGuide Server as a Site Server, then I installed MapGuide
> Web Server Extensions - the bundled configuration (PHP). I used the
> default value of 127.0.0.1 for the SIte Server.
> I chose Custom Setup type so I can install the API documentation.
> Then I proceed with the chapter Configuring MapGuide Web Server Extensions
> on Windows - Cofigure with Apache. There is a section: Common
> Configuration Steps that ask to edit httpd.conf like this:
> There are some steps you must perform whether you are using PHP or JSP as
> a development environment.
> ■ If you are using the Site Administrator or plan to use PHP as a
> development
> environment, configure Apache to process files with the .php extension.
> Edit httpd.conf. Look for the configuration of the PHP engine. Ensure it
> is set as follows, or add the following to the file as necessary.
> ScriptAlias /php/ "C:/Program Files/MapGuideOpenSource/
> WebServerExtensions/Php/"
> Action application/x-httpd-php "/php/php-cgi.exe"
> AddType application/x-httpd-php .php
> ■ In the Dynamic Shared Object Support section, ensure that the rewrite
> module is enabled. If there is a comment character at the beginning of the
> line, remove it so it looks like this:
> LoadModule rewrite_module modules/mod_rewrite.soThere are some steps you
> development
> Then the section Configuring Apache to Use PHP says:
> To use PHP as the development environment with the Apache HTTP Server,
> add the following declarations at the end of httpd.conf.
> ScriptAlias /mapguide/mapagent/mapagent.fcgi
> "C:/Program Files/MapGuideOpenSource/WebServerExtensions/
> www/mapagent/MapAgent.exe"
> AliasMatch ^/mapguide/mapviewerajax/([^\?])(.*)$
> www/mapviewerphp/$1$2"
> Alias /mapguide/mapviewerajax
> www/mapviewerphp/ajaxviewer.php"
> AliasMatch ^/mapguide/mapviewerdwf/([^\?])(.*)$
> Alias /mapguide/mapviewerdwf
> www/mapviewerphp/dwfviewer.php"
> Alias /mapguide
> "C:/Program Files/MapGuideOpenSource/WebServerExtensions/www/"
> <Directory
> "C:/Program Files/MapGuideOpenSource/WebServerExtensions/www/">
> AllowOverride All
> Options All
> Order allow,deny
> Allow from all
> AddHandler cgi-script .exe
> RewriteEngine on
> RewriteRule .* - [E=REMOTE_USER:%{HTTP:Authorization},L]
> </Directory>
> Save the changes and restart the Apache server.
> I have follwed these stepas, and when I try to Verify the Configuration I
> get this errors:
> 1. Testing the Map Agent:
> I try to connect to http:
> //localhost:8008/mapguide/mapagent/mapagent.fcgi?OPERATION=ENUMERATERESOURCES&VERSION=1.0.0&
> LOCALE=en&RESOURCEID=Library://&TYPE=&DEPTH=-1
> After I type Administrator and admin I get:
> Cannot establish connection. Exception occurred in method
> MgServerConnection.Open at line 95 in file .\Services\ServerConnection.cpp
> After I change localhost to 127.0.0.1 and type Administrator and admin I
> get the same error.
> 2. Testing the Site Administrator
> I try to connect to: http://localhost:8008/mapguide/mapadmin/login.php
> After I type Administrator and admin I get: Authentication failed. Please
> enter a valid username and password.
> Same error if I change localhost with 127.0.0.1
> 3. Testing the Web Server Extensions
> http://localhost/mapguide/mapviewerajax/ajaxviewer.php?
> WEBLAYOUT=Library://ATest.WebLayout
> The error: The page cannot be displayed.
> PLEASE LET ME KNOW WHAT I AM DOING WRONG.
> Thank you,
> Dorin
View this message in context: http://www.nabble.com/MapGuide-Open-Source-Instalation-issues-tf4120930s16610.html#a11730556
