AW: [mapguide-users] creating points at runtime / display problem/ .NET
G.E.O.-Consulting / Hans Morschell moerschell at geo.co.at
Tue Jun 5 12:37:03 EDT 2007
yes I am sure the point is within current map, I can read the point from
featuresource, the coordinates are correct
yes I am sure the projection is correct I have read the projection of the
map and compared it
even if I save the point to an existing featuresource / layer the point is
not drawn
somewhat curious, do you have any other idea ?
thanks, Hans
  _____
Von: mapguide-users-bounces at lists.osgeo.org
[mailto:mapguide-users-bounces at lists.osgeo.org] Im Auftrag von Kenneth,
GEOGRAF A/S
Gesendet: Dienstag, 5. Juni 2007 17:27
An: MapGuide Users Mail List
Betreff: Re: [mapguide-users] creating points at runtime / display problem/
.NET
Are you sure that the new point is actually visible within the current map?
Are you sure the FeatureSource projection is correct?
Can you get the point to display, if you save the FeatureSource and open it
with Studio?
Someone complained about not being able to use feature sources from the
session repository, is this the case?
Regards, Kenneth, GEOGRAF A/S
G.E.O.-Consulting / Hans Morschell wrote:
Hello,
I am having a problem with displaying points that I have created during
runtime. I can create the featuresource, create the layer using a XML file,
add the layer to the map and after that I add a point to the empty layer,
set the layer visible and force to refresh, and finally save the map; I have
controlled the steps of my source according to the examples in the
dotnetviewer sample application (findaddress.aspx etc.).
Nevertheless the point is not shown in map display after a map refresh, but
in the legend the new layer is visible, the style is shown correctly, I can
read the point in source code using a feature reader and I do not have any
error messages.
Has anybody some ideas what I am doing wrong, am I missing something ?
My configuration: MgOS 1.2 Beta 2, .Net environment, source in VB
kind regards, Hans
  _____
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070605/4b461a22/attachment.html
