[mapguide-users] Incorrect key fields when using views/queries inMGOS 1.2 RC1
Dave Wilson dave.wilson at autodesk.com
Thu Jun 14 11:00:37 EDT 2007
Can I assume you are using ODBC?
The key column is in a drop down and you specify it. The "random" selected columns are likely float/decimal columns that are being defaulted as candidates for X,Y,Z geometry columns. These aren't required if you aren't attempting to display point geometries. Don't select the Geometry checkbox unless you plan to create a point geometry layer.
Regards,
Dave
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Ismael Cams
Sent: Thursday, June 14, 2007 8:38 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Incorrect key fields when using views/queries inMGOS 1.2 RC1
Hello,
is there any possibility to change the key fields for views/queries. I have
an query in Access on a table where I have defined a primary key. But when
creating a data source MapGuide seems to choose some random fields for the
key which I can not adapt.
I suspect that this behaviour is the reason why I can not select any feature
(although they are displayed correctly).
Thanks in advance.
Ismaël
View this message in context: http://www.nabble.com/Incorrect-key-fields-when-using-views-queries-in-MGOS-1.2-RC1-tf3922083s16610.html#a11121303
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
