[mapguide-users] Java enhancements (Was: Good
Development Environment for MGOS)
Joel Carranza
jec at gatekeeper.com
Thu Mar 8 13:26:36 EST 2007
Jason,
I put my requests into the ticket tracking system. Glad to see that this
is up and running again, although I would mention to whomever maintains
it that the links on the "New Ticket" page are all broken.
For us, quality java support in MGOS is critical. Luckily, the support
for java is definately there, it just needs a little polish :) I don't
know how hard it is to customize things in SWIG, but I think the real
issue here is what to do with the existing API. Try to make it backward
compatible (don't see how that could happen), create a new API? Maintain
two APIs?
A couple of better-informed design decisions need to be made on how the
Java API should look, and these decisions should be done quickly, so
that java developers can know what to expect.
I'm definately available for input/feedback, but at this moment, I don't
have the time available for getting my hands dirty with SWIG. I could
probably write some perl code to rewrite the java source faster than I
could make one change in SWIG :)
Joel
Jason Birch wrote:
> Joel wrote:
> But, I suspect that SWIG (the toolkit which generates this binding automatically) could be configured to provide a interface which better adheres to java standard.
> There's been some discussion of this on the -internals list (prompted by your initial post).
> http://www.nabble.com/RE%3A-RE%3A--mapguide-users-GoodDevelopment-Environment-for-MGOS-p9364766s16610.html <http://www.nabble.com/RE%3A-RE%3A--mapguide-users-GoodDevelopment-Environment-for-MGOS-p9364766s16610.html>
> It looks like Bob has not seen a huge interest in Java either (I'm assuming either through Autodesk or watching these forums). However, I would really like to see MapGuide support Java as well as it does PHP or .Net. It would be great if we could get enough interest (volunteers) to work on this. It's an area where we have the opportunity to be both cross-platform, and BETTER than other solutions.
> A jar containing the java source files with javadocs embedded would greatly facilitate development within Eclipse (or other java IDE).
> Hmm. I think that all of these should probably be entered as an enhancement request at http://trac.osgeo.org/mapguide/ <http://trac.osgeo.org/mapguide/> so that we don't loose track of them.
> Jason
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070308/1db9ba81/attachment.html
