[mapguide-users] Extending a feautre property list via SQL
Nico Alberti nico at langhirano.it
Tue Mar 13 04:56:42 EDT 2007
2007/3/12, Dave Wilson <dave.wilson at autodesk.com>:
> You should use the ODBC provider to make connections for joining for
> non-geographic data. Don't specify a geometry property in the editor
> once you make the connection. Use this as a secondary source and join to
> your geometry data.
I tried and it would probably work. Unfortunately now the mapserver
process slows down a lot and crashes often. Is this Join to an odbc
source so resource intensive? It seems that my system can not handle
correctly such a load.
However, thank you for your help, I will keep on testing.
Ciao
Nico
