[mapguide-users] mgservice at 100%
George McLean gmclean at gorge.net
Tue Mar 20 14:46:33 EDT 2007
Thanks Traian!
That did the trick. I tried to run db_recover by modifying the
RepositoryAdmin.php but that sent the CPU into 100% with dbrecover.exe.
What are those files that you suggested I delete?
Thanks again
George
Traian Stanev wrote:
> Sometimes when I get problems with the repository, I manually delete all
> files named __db.00X (where X is a number) under the Repositories
> directory. This is a non-scientific suggestion though and is not
> guaranteed to work...
> Traian
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of George
> McLean
> Sent: Tuesday, March 20, 2007 1:04 PM
> To: MapGuide Users Mail List
> Subject: Re: [mapguide-users] mgservice at 100%
> Is there any way to know approximately how long the cold backup should
> take? I am running backupofflinerepositories.bat and the CPU has been at
> 100% for about 20 minutes with the db_checkpoint.exe taking all the CPU.
> I see the backupRepositories folder and subfolders but there are no
> files in them yet.
> Is it possible the repository database is in a state where the backup
> does not work? Are there any tools to try and repair it? This is a
> development system so if I had to rebuild it from scratch that would not
> be a huge loss but it would be good to learn how to fix this sort of
> problem.
> Thanks
> George
> Steve Dang wrote:
>> Hi George,
>> I suggest you to perform a "cold" backup then a restore of the
>> repositories. The instruction should be under the MapGuide Server
>> installation directory:
>> 	..\Server\RepositoryAdmin\RepositoryAdmin.pdf
>> Steve.
>> McLean
>> Sent: Monday, March 19, 2007 6:26 PM
>> Subject: [mapguide-users] mgservice at 100%
>> I am having problems with mgserver.exe running at 100% in Windows XP.
>> I tried repair of mgserver and extensions but that did not solve it so
> I
>> uninstalled extensions and server then reinstalled. This did not solve
>> the problem either.
>> I found the discussion below and have stopped the service in task
>> manager and tried running as an application from the command line
> using
>> 'mgserver run'. After starting as an application my CPU is still
> pegged
>> at 100% with mgserver.exe as the process using all the CPU
>> Before re-installing I made copy of all the files and folders under
> the
>> C:\Program Files\MapGuideOpenSource folder so I am assuming I have
>> everything backed up.
>> Should I uninstall and then delete all the repositories etc then
>> re-install? Any other suggestions?
>> Thanks
>> George
>> Subject:
>> RE: [mapguide-users] Site corrupt - MG Server fails to start
>> From:
>> "Bruce Dechant" <bruce.dechant at autodesk.com>
>> Date:
>> Mon, 20 Nov 2006 13:07:36 -0800
>> To:
>> <users at mapguide.osgeo.org>
>> To:
>>> The files might not actually be corrupt, but may have not been closed
>>> properly (example: due to power outage). When the server starts it
>>> tries to "clean up" the repositories using the generated log files.
>>> Under certain circumstances this can take longer then the Windows
>>> Service Control Manager allows for a service starting up. The thing
> to
>>> do in this case is to not run the server as a service and instead run
>>> it interactively as an application to give the server time to cleanup
>>> the repository. Once the repository has been cleaned up you can stop
>>> the server application and restart it as a service. Note: that you
>>> should not have to do this under normal operating conditions.
>>> Bruce
>>> *From:* Jason Birch [mailto:Jason.Birch at nanaimo.ca]
>>> *Sent:* November 18, 2006 9:41 PM
>>> *To:* users at mapguide.osgeo.org
>>> *Subject:* RE: [mapguide-users] Site corrupt - MG Server fails to
>> start
>>> Good cautionary tale.
>>> If anyone is not backing up their repositories, they should strongly
>>> consider it. I haven't seen any problems yet, but the repositories
> are
>>> file-based and are subject to corruption in the case of interrupted
>>> writes, etc.
>>> There is a RepositoryAdmin directory in the Server installation that
>>> contains some utilities for doing this, and instructions. You can
> find
>>> a copy of the isntructions here:
> https://mapguide.osgeo.org/source/browse/*checkout*/mapguide/trunk/MgDev
>> /Server/RepositoryAdmin/MgOpenSourceRepositoryAdmin.pdf
>>> Hmm. It would be nice if we could leverage an RDBMS data store to
>>> store the repository info. This would kinda break the managed data
>>> idea, but it would eliminate the load balancing problems around
>>> session access. I don't really like storing my data with the site
>>> configuration info anyway :)
>>> Jason
>>> *From:* Andy Morsell
>>> *Sent:* Sat 2006-11-18 12:14 PM
>>> *Subject:* [mapguide-users] Site corrupt - MG Server fails to start
>>> I have no idea how this happened, but it is rather disconcerting.
>>> Luckily it was only the Site data that was a problem and that my
>>> Library seems to be fine. Otherwise I would be reaching into my
>>> backups to restore from.
>>> Subject:
>>> From:
>>> "Andy Morsell" <amorsell at spatialgis.com>
>>> Date:
>>> Mon, 20 Nov 2006 13:13:05 -0800
>>> To:
>>> To:
>>> Thanks for the information Bruce, I'll try that next time I see these
>>> symptoms (hopefully never again). Dave Wilson also mentioned in the
>>> MapGuide Enterprise discussion group that if the files under Site are
>>> deleted, then server will re-create them when started. I tested this
>>> and it worked. You will end up losing any users and groups you setup
>>> (and I'm sure other things, but I don't know exactly what), but I was
>>> pleasantly surprised to see that resource service paths were not
>>> effected (my repository is not in the default location).
>>> Andy
>>> *From:* Bruce Dechant [mailto:bruce.dechant at autodesk.com]
>>> *Sent:* Monday, November 20, 2006 1:08 PM
>> start
> to
>>> Bruce
>> start
> are
>>> writes, etc.
> find
>>> Jason
>>> Subject:
>>> From:
>>> "Jason Birch" <Jason.Birch at nanaimo.ca>
>>> Date:
>>> Mon, 20 Nov 2006 13:18:10 -0800
>>> To:
>>> To:
>>> If you're talking about the same paths that I think you are, they are
>> stored in the serverconfig.ini file.
>>> Jason
>>> ________________________________
>>> From: Andy Morsell
>>> Sent: Mon 2006-11-20 1:13 PM
>>> To: users at mapguide.osgeo.org
>>> Subject: RE: [mapguide-users] Site corrupt - MG Server fails to start
>>> Subject:
>>> From:
>>> "Brad Nesom" <kidsmake6 at msn.com>
>>> Date:
>>> Mon, 20 Nov 2006 15:47:17 -0600
>>> To:
>>> To:
>>> Is there a service or application that could be checked to see if the
>>> cleanup is still running or completed?
>>> *Sent:* Monday, November 20, 2006 3:08 PM
>> start
> to
>>> Bruce
>> start
> are
>>> writes, etc.
> find
>>> Jason
>>> Subject:
>>> From:
>>> "Steve Dang" <steve.dang at autodesk.com>
>>> Date:
>>> Mon, 20 Nov 2006 14:12:25 -0800
>>> To:
>>> To:
>>> No, the server automatically runs this cleanup and completes it at
>>> startup time. If there is a problem, the server will stop and throw
> an
>>> exception.
>>> Steve.
>>> *From:* Brad Nesom [mailto:kidsmake6 at msn.com]
>>> *Sent:* Monday, November 20, 2006 2:47 PM
>> start
>> start
> to
>>> Bruce
>> start
> are
>>> writes, etc.
> find
>>> Jason
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
