[mapguide-users] Buffer Error No coordinate system specified
Bruce Dechant bruce.dechant at autodesk.com
Mon Mar 26 14:14:35 EDT 2007
It looks like you are still not setting the OGC WKT as the exception you
are seeing is because it is still blank/empty.
Are you setting the coordinate system via the SetCoordinateSystemWkt()
API on the CreateFeatureSource parameters object? As you need to set
this to the OGC WKT you want to use.
Also, it needs to be a full OGC WKT and not a short code like "LL84".
Thanks,
Bruce
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of SUDIP
(INDIA)
Sent: March 22, 2007 12:08 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Buffer Error No coordinate system specified
Hello All,
When buffered somthing it sahows a error msg.
Invalid argument(s): No coordinate system specified. Exception occurred
in
method MgServerCreateFeatureSource.CreateFeatureSource at line 64 in
file
c:\build_tux_area\mgdev_opensource\server\src\services\feature\ServerCre
ateFeatureSource.cpp
I changed the coordinate system to LL84 that is WGS 84
But  till it shows same Error
Can any one help Me
Waiting for ur reply.
Sudip Barman
View this message in context:
http://www.nabble.com/Buffer-Error-No-coordinate-system-specified-tf3445
675s16610.html#a9608992
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
