[mapguide-users] RE: RE: MySQL Database Feature Source CordianteSystem
Dhirendra Kumar dhirendra.mgos at gmail.com
Thu May 31 02:59:42 EDT 2007
Hi Dave,
Thankyou for your quick replay and valuable suggestion. Now i can Make
layers and view also. Thankyou once again.
Regards,
Dhirendra Kumar
Dave Wilson-3 wrote:
> I reread the email chain and noticed you talked about Points and
> Longitude and Latitude columns. If that is the case you shouldn't use
> the MySQL provider, but instead use an ODBC connection. You will need to
> install the MySQL ODBC Connector on your server system (it's the ODBC
> driver for MySQL).
> You likely don't have any geometry because there are no geometry type
> columns in your data.
> Regards,
> Dave
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kenneth,
> GEOGRAF A/S
> Sent: Wednesday, May 30, 2007 8:11 AM
> To: MapGuide Users Mail List
> Subject: Re: [mapguide-users] RE: MySQL Database Feature Source
> CordianteSystem
> I think you have a problem with the database schema then.
> I don't think there is any live support, as this is an open source
> project.
> If you want real support, consider purchasing MapGuide Enterprise from
> Autodesk.
> Its basically the same product, but you get access to Autodesk support.
> Regards, Kenneth, GEOGRAF A/S
> Dhirendra Kumar wrote:
> Hi Kenneth,
> I am waiting for your replay. Please read my previous message for
> detail.
> Regards,
> Dhirendra Kumar
> 	Hi Kenneth,
> 	As per your suggestion i can view all tables during layer
> creation but
> 	after selection of table lower Geometry combo box is empty not
> any data in
> 	this combo box. Then how will i select "Geometry".In my process
> any thing
> 	wrong ?. Kenneth i want to live chat with any MGOS Expert, Is it
> possible
> 	Regards,
> 	Dhirendra Kumar
> 	Kenneth, GEOGRAF A/S wrote:
> 		Oh, my fault. It takes the two coorner coordinates, not
> a center
> 		coordinate.
> 		You must enter correct coordinates in the "lower left"
> and "upper right"
> 		boxes.
> 		You must also select the correct coordinate system.
> 		When you create a new layer, you must select a
> datasource.
> 		After selecting the data source, the names of the tables
> in the
> 		datasource should display in the combo box "Feature
> class".
> 		You can select the desired table here.
> 		You can select the column containing the geometry in the
> combobox
> 		"Geometry".
> 			Hi Kenneth,
> 			First i want to give you thankyou for your quick
> replay. Acording to you
> 			when i go to create Layer then i can view only
> Data resource used in
> 			this
> 			layer  field and select saved Datasource name
> and i save this layer as a
> 			same name of Datasource But i am not getting
> tables name individually
> 			and
> 			after that i make map using this layer then i
> can view only Coordinate
> 			system option and initial view option for
> initial Zoom setting option
> 			But i
> 			am not getting any option for center coordinate.
> For Information i am
> 			using
> 			MGOS 1.1.0, MySQL 5.0 and Autodesk mapguide
> studio 2007.So please help
> 			me.
> 			Regards,
> 			Dhirendra Kumar
> 				You cannot see the tables on the
> datasource. That is by design. The
> 				tables are considered schema's within
> the datasource.
> 				You should be able to see all the
> tables, when you are creating the
> 				layer.
> 				When working with databases, I would
> recommend not using any
> 				non-english
> 				charaters, even though the database
> supports it. Many third-party
> 				applications break when they encounter
> such characters.
> 				Did you enter the center coordinate on
> the map?
> 				Try looking at the MapGuide log files.
> They should be in
> 				C:\Program
> Files\MapGuideOpenSource\Server\Logs
> 				There might be a message if something
> went wrong.
> 				Hi Kenneth,
> 				As per your suggestion first i create
> one datasource (Connection was
> 				succesfull) and after that create layer
> with existing datasource, and
> 				also
> 				create map and mention cordinate system.
> But my problem is still same.
> 				In
> 				MySQL Database one table with 15 fields
> and i want to create Points on
> 				field
> 				Longitude and Latitude. Any problem in
> this field name ? During
> 				creation
> 				of
> 				datasource, not getting any option to
> select any specific table but
> 				when
> 				i
> 				use join feature then i can view all
> tables name for join purpose.
> 				Help
> 				me......
> 				Regards,
> 				Dhirendra Kumar
> 				As Dave wrote, you must zoom in to the
> data.
> 				Since you cannot enter coordinates on
> the layer preview, it will not
> 				show.
> 				To view data you must:
> 				Create a datasource.
> 				Create a layer with the datasource.
> 				Create a map.
> 				Select the coordinate system.
> 				Specify the center coordinate manually.
> 				Add the layer.
> 				Press refresh.
> 				If it still won't show, doublecheck the
> connection on the datasource,
> 				and press the "Test connection" button.
> 				Hi Dave,
> 				You are right, not any fied in autodesk
> studio 2007 for mention
> 				cordinate
> 				system but when i am creating layer
> using data source, then why
> 				Layer
> 				is
> 				not
> 				showing in map preview window of
> Autodesk studio 2007. Please help
> 				me
> 				....... Thankyou in Advance.
> 				Regards,
> 				Dhirendra Kumar
> 				As per my previous email unless you have
> the new MGOS beta there is
> 				no
> 				field to specify a coordinate system
> override since currently MySQL
> 				doesn't support coordinate systems in
> the native schema. You can
> 				specify
> 				the correct coordinate system in your
> map but you will have to zoom
> 				and
> 				find the data to set the extent
> yourself.
> 				Regards,
> 				Dave
> 				-----Original Message-----
> 				From:
> 				Dhirendra
> 				Kumar
> 				Sent: Monday, May 28, 2007 5:07 AM
> 				To: mapguide-users at lists.osgeo.org
> 				Subject: [mapguide-users] MySQL Database
> 				System
> 				Hi All,
> 				I have successfully established
> connection of MySQL 5.0 Database
> 				and
> 				mapguide 1.1.0 with the help of Autodesk
> MapGuide Studio 2007 but
> 				when
> 				creating Layer using this data source
> then layer is not showing in
> 				autodesk
> 				Layer Preview window, I think this is
> happning due to cordinate
> 				system,
> 				If i
> 				am right then where is option of
> providing cordinate system of
> 				MySQL
> 				data
> 				source ? If i am wrong then please give
> me idea, How to solve this
> 				problem ?
> 				Regards,
> 				Dhirendra Kumar
> 				View this message in context:
> http://www.nabble.com/MySQL-Database-Feature-Source-Cordiante-System-tf3
> 				827380s16610.html#a10834515
> 				Sent from the MapGuide Users mailing
> list archive at Nabble.com.
> 				mapguide-users mailing list
> 		_______________________________________________
View this message in context: http://www.nabble.com/MySQL-Database-Feature-Source-Cordiante-System-tf3827380s16610.html#a10888456
