[mapguide-users] Help needed on transfering files from ArcGIS to Mapguide
Kenneth, GEOGRAF A/S ks at geograf.dk
Mon Nov 5 02:47:14 EST 2007
There are no load procedures in WebStudio, only in Autodesk MapGuide Studio.
MapGuide Studio has specific editors for each type of provider, and
apparently hides the SHP provider.
You can get around it, by editing the providers.xml file on the server
and create two
entries for the SHP provider, naming one "OSGeo.SHPextra.3.3.1".
That will bypass the Studio provider recognition, and you get the
default editor.
Beware that the name of the provider is stored in layers, so you must
re-edit the providers.xml file after a server upgrade.
If you have the SHP provider, you should be able to enter the path to
the files and have it loading.
For SDF, you can upload the SDF file into the server, but I am unsure
how to do this with WebStudio.
In any case, you will not get far without Autodesk MapGuide Studio.
Regards, Kenneth, GEOGRAF A/S
Mansoureh Sadrykia skrev:
> Hi!
> The load procedure is available in mapguide studio, I'm not sure about
> the web studio! Even if you have mapguide studio trial version, you
> can load your shp file to mapguide os.
> About the fdo provider for shp, I had the same problem; I never could
> find FDO provider for shp in mapguide studio!!!
> Hope it helps,
> Regards
> */NepaliManchhe <ayush_2000 at yahoo.com>/* wrote:
>     Hi,
>     Thanks for the suggestion but i couldnt find any "load procedures"
>     anywhere
>     in the webstudio. If you meant the uploading feature, i tried that
>     out too
>     but didnt work! I tried downloading FDO2FDO and tried to create a
>     SDF file
>     from the available shape files and then uploading it to a feature
>     source but
>     then that didnt work out too.. I really dont know what to do.
>     HELP!
>     If anyone would want to try out, i've attached the shape file +
>     the database
>     files along with this post. If you DO manage to create layers
>     successfully,
>     please do write me back.
>     http://www.nabble.com/file/p13581774/petrol.zip petrol.zip
>     View this message in context:
>     http://www.nabble.com/Help-needed-on-transfering-files-from-ArcGIS-to-Mapguide-tf4747259s16610.html#a13581774
>     Sent from the MapGuide Users mailing list archive at Nabble.com.
>     _______________________________________________
>     mapguide-users mailing list
>     mapguide-users at lists.osgeo.org
>     http://lists.osgeo.org/mailman/listinfo/mapguide-users
> __________________________________________________
> Do You Yahoo!?
> Tired of spam? Yahoo! Mail has the best spam protection around
> http://mail.yahoo.com
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20071105/299a574d/attachment.html
