[mapguide-users] Application develop environment
Jackie Ng jackie.ng at aecsystems.com.au
Tue Nov 13 04:41:42 EST 2007
Does configPath actually point to your webconfig.ini?
It could be that it's looking for webconfig.ini in the "temporary asp.net
files" folder.
Have you tried Page.ResolveUrl() for the webconfig.ini path?
- Jackie
Gunter Becker wrote:
> Hi,
> I wonder how to set up my develop environment. I'd like to have my
> webapplication on a different computer (on my client machine) than the
> MapGuide OpenSource Software (on the server).
> Currently I'm developing with Visual Studio and the .NET Framework. I
> copied the required dll's into the bin folder and also copied the
> "webconfig.ini" to my webapplication (into the root directory).
> In the "webconfig.ini" I've done the following changes.
> - changed the IpAddress-Parameter under [SiteConnectionProperties] to the
> servers IP
> - changed the ResourcesPath to an UNC-Path to Resource folder
> (\\vm-mgos\MapGuideOpenSource\WebServerExtensions\www\mapagent\Resources)
> So, most time this works for me but sometimes I notice this exception:
> - Failed to retrieve message for "MgFileIoException". (happens at
> MapGuideApi.MgInitializeWebTier(configPath))
> Are there some other settings I have to do?
> Gunter
View this message in context: http://www.nabble.com/Application-develop-environment-tf4796625s16610.html#a13722662
