[mapguide-users] Mapguide 2.0 Beta1 vs 1.2 performance
Paul Spencer
pagameba at gmail.com
Thu Nov 22 11:30:37 EST 2007
Oh, right. OpenLayers (the library that handles the map image)
automatically buffers non-tiled images by a certain amount to give
some 'continuity' when panning. By default, the ratio applied is 1.5
I think, so it requests an image 1.5 x wider and higher.
We need to add an option to the Map tag in the ApplicationDefinition
to allow adjusting the ratio used by OpenLayers. I've filed an
enhancement bug in trac for this (http://trac.osgeo.org/mapguide/ticket/327
Cheers
Paul
On 22-Nov-07, at 9:07 AM, Bruno Scott wrote:
> here is my test today with GG and AGG
> mg2.0+AGG-fusion 17 sec
> mg2.0+AGG+fusion 30 sec
> mg2.0+GD-fusion 10 sec
> mg2.0+GD+fusion 20 sec
> GD seems faster than AGG
> A little precision, i have a huge screen resolution 1900x1200
> I did my test full screen
> I have also noticed something, the image generated by fusion is a
> lot larger
> than the one without fusion.
> We see it when we pan, the image is about 20% bigger than what we
> see on the
> screen.
> 20% bigger in 4 direction make the image about twice big.
> And with a resolution of 1900x1200 this could explain the gap in
> performance
> with or without fusion.
> Bruno
> Bruce Dechant wrote:
>> The performance difference can be attributed to the fact that this
>> is a
>> Beta version being compared to a Release version.
>> Some things to consider:
>> - 1.2 used the GD renderer, whereas, 2.0 is using the new AGG
>> renderer
>> (looks much better)
>> - there are several places in the code that have not been optimized
>> yet
>> (algorithms, memory usage, thread usage, etc...)
>> - Fusion is a brand new feature of the 2.0 release and has not been
>> optimized either
>> - this is a Beta and doesn't necessarily reflect the final release
>> code.
>> Thanks,
>> Bruce
>> -----Original Message-----
>> From: mapguide-users-bounces at lists.osgeo.org
>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Paul
>> Spencer
>> Sent: November 21, 2007 10:04 AM
>> To: MapGuide Users Mail List
>> Subject: Re: [mapguide-users] Mapguide 2.0 Beta1 vs 1.2 performance
>> It uses the mapdefinition that is set in the application definition,
>> if its a tiled map then it should be tiled in the client, otherwise
>> it
>> should be a regular old map draw.
>> Has anyone else got feedback on this? I saw fusion running on a
>> laptop yesterday, not tiled, full screen, and it was milliseconds
>> (<500ms) to pan/zoom (didn't look at select).
>> Paul
>> On 21-Nov-07, at 3:22 AM, Zac Spitzer wrote:
>>> sounds like fusion ain't hitting the tile cache???
>>> On Nov 21, 2007 6:44 PM, Bruno Scott <bscott at geomapgis.com> wrote:
>>>> I have 2 identical vm-ware with windows 2003 running on the same
>>>> machine
>>>> I start one of the vm-ware, I do the testing, I stop it and then
>>>> start the
>>>> other to do the other bench Bench is done on the sheboygan sample
>>>> at 1:5000
>>>> scale
>>>> MG 2.0 with fusion Mg 2.0 without
>>>> fusion Mg 1.2
>>>> pan 29 sec 12 sec 2
>>>> sec
>>>> select 28 sec 12 sec 2
>>>> sec
>>>> I know it's only a beta but why is that slow?
>>>> Bruno Scott
>>>> View this message in context:
>>>> http://www.nabble.com/Mapguide-2.0-Beta1-vs-1.2-performance-tf4848550s16610.html#a13872479
>>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>>> _______________________________________________
>>>> mapguide-users mailing list
>>>> mapguide-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>> Zac Spitzer
>>> http://zacster.blogspot.com/
>>> +61 405 847 168 (aussie moible)
> View this message in context: http://www.nabble.com/Mapguide-2.0-Beta1-vs-1.2-performance-tf4848550s16610.html#a13897170
