[mapguide-users] MG 1.1 with Opera?
uXuf
yousuf.hassan at gmail.com
Wed Nov 28 20:59:06 EST 2007
Okay so this isn't actually hindering my work but I just thought to give it a
whirl on Opera so it came out. I tried the SHIFT+G thing and it appears that
I have to press the key combo *every* time the map renders. So probably
Opera goes out of the window, and so do
http://www.w3schools.com/browsers/browsers_stats.asp 1.6% of traffic.
But I don't think people who have stable applications running on 1.x would
be very willing to upgrade any time sooner, so it's more of a utility than
an incentive, if any one decides to fix it.
Just my two cents.
uXuf
James Card wrote:
> On Wed, 28 Nov 2007 16:03:11 -0800, uXuf <yousuf.hassan at gmail.com> wrote:
>> Has anybody tried running the ajax map viewer with Opera? It wouldn't at
>> least run at my end. Is anybody else experiencing this with Opera? I
>> know all the talk about the market share thing, but just wanted to
>> tip-off people.
> Opera almost works. If you switch Opera to user-mode (SHIFT+G) the map and
> legend images will load, then switch back (SHIFT+G again) and the map
> displays properly. Map controls all seem to work _if_ you switch to
> user-made and back again to force the map refresh after each zoom or pan
> or other operation. This suggests to me that some, probably minor,
> modification in the event-handling code would have Opera working.
> The other big difference is that Opera disables JavaScript access to
> right-click events by default (until the user enables the "Allow script to
> receive right clicks" option in their preferences) so the context-menu
> actions (such as buffer and measure) in MapGuide won't be accessible. The
> workaround to this problem is to make sure that all those functions are
> also available on the toolbar or in the task pane when setting up the
> layout.
> Of course, with the change to the Fusion interface in MapGuide Open Source
> 2.0 there may be less incentive for someone to make the current AJAX
> viewer work with Opera.
> James Card
> 209-578-5580
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/MG-1.1-with-Opera--tf4894071s16610.html#a14017920
