[mapguide-users] Insert Order In MySql Affect to theMapGuideSelection?
ary sucaya ary.sucaya at yahoo.com
Fri Nov 30 06:24:35 EST 2007
Well, finally i infer that Mapguide selection still contain a hidden bug. Here is my simple php:
$regionGeometryData = $featureReader->GetGeometry('Geometry');
$agfReaderWriter = new MgAgfReaderWriter();
$regionGeometry = $agfReaderWriter->Read($regionGeometryData);
$queryOptions = new MgFeatureQueryOptions();
$queryOptions->SetSpatialFilter('BOUNDARY', $regionGeometry, MgFeatureSpatialOperations::Intersects);
$layer = $map->GetLayers()->GetItem("INDEX");
$featureReader = $layer->SelectFeatures($queryOptions);
$regionGeometryData comes from SDF file. By this geometry, i try to select another layer  that is intersects with this. MGOS give me some records in layer INDEX that is not have an intersection even far away from $regionGeometryData.
I will try to file a ticket soon for this issues..
Ary Sucaya
----- Original Message ----
To: MapGuide Users Mail List <mapguide-users at lists.osgeo.org>
Sent: Thursday, November 29, 2007 10:38:22 PM
Subject: RE: [mapguide-users] Insert Order In MySql Affect to theMapGuideSelection?
The bounding box operations would explain why you are getting a polygon selected even when you click outside of its boundary.  Read the note at the top of this page if you would like to confirm that this is indeed MySQL's behaviour: http://tinyurl.com/2mk9aa
I'm not a heavy MySQL user, but I'm pretty sure that insertion order affects the order that rows are returned in (unless you're explicitly ordering them, and I am pretty sure that MapGuide does not).  If this is the case, then in combination with #313 this might explain why you are getting different polygons within the multipolygon selected?  Maybe I don't understand the issue properly.
If this works with multipolygon SDF files with no issues though, it is either a problem with MySQL itself, or a problem with the MySQL FDO provider.  I would strongly encourage you to file a ticket on the FDO Trac instance (instructions here: http://trac.osgeo.org/fdo/wiki/SubmitTicket ).  For best results, please include a description (preferably with small screenshots illustrating the problem) and  include a mysqldump of the geometry that is causing the problem to allow the developers to easily reproduce it.
Jason
Subject: Re: [mapguide-users] Insert Order In MySql Affect to theMapGuideSelection?
http://trac.osgeo.org/mapguide/ticket/313 is not what i'm seeing now. That's another problem of multipolygon. What i don't understand is why the sequence of records insertion affect MGOS select behaviour? If MySql perform geometric operation only on their bounding box, then 'my selection problem' will always happens even i change the sequence of records insertion
      ____________________________________________________________________________________
Never miss a thing.  Make Yahoo your home page.
http://www.yahoo.com/r/hs
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20071130/97e09082/attachment.html
