[mapguide-users] adding marker layer in mapguide 1.2 API
ZoffoMan
zoffo at adelphia.net
Thu Oct 4 14:28:08 EDT 2007
Has anyone solved this .net on 1.2.
The example "works" but does not show a pushpin.
I made a similar layer in my code and same results - no image
I've tried turning on off text as well.
Here is the templated xml (double double quoates are treated as single
double quotes):
<?xml version=""1.0"" encoding=""UTF-8""?>
<LayerDefinition version=""1.1.0""
xmlns:xsi=""http://www.w3.org/2001/XMLSchema-instance""
xsi:noNamespaceSchemaLocation=""LayerDefinition-1.0.0.xsd"">
<VectorLayerDefinition>
<ResourceId></ResourceId>
<FeatureName>{0}Point</FeatureName>
<FeatureNameType>FeatureClass</FeatureNameType>
<Geometry>Geometry</Geometry>
<VectorScaleRange>
<MinScale>1</MinScale>
<MaxScale>30000001</MaxScale>
<PointTypeStyle>
<DisplayAsText>true</DisplayAsText>
<AllowOverpost>false</AllowOverpost>
<PointRule>
<LegendLabel></LegendLabel>
<PointSymbolization2D>
<W2D>
<Unit>Points</Unit>
<SizeContext>DeviceUnits</SizeContext>
<SizeX>500</SizeX>
<SizeY>500</SizeY>
<W2DSymbol>
<ResourceId>Library://Samples/Sheboygan/Symbols/BasicSymbols.SymbolLibrary</ResourceId>
<LibraryItemName>PushPin</LibraryItemName>
</W2DSymbol>
</W2D>
</PointSymbolization2D>
</PointRule>
</PointTypeStyle>
</VectorScaleRange>
</VectorLayerDefinition>
</LayerDefinition>
View this message in context: http://www.nabble.com/adding-marker-layer-in-mapguide-1.2-API-tf3992493s16610.html#a13045857
