[mapguide-users] MgByteReader and XmlSerializer question
Maksim Sestic max at geoinova.com
Thu Oct 11 03:32:21 EDT 2007
Kenneth, I'm stuck with commercial version of MGE... So, basically, What I
See Is What I Get :-)
My intention was to build a small .NET wrapper to offer some neatly picked
functionality to 3rd party developers leaning on present MGE implementation.
I can't let them browse data repositories as they will since I need to keep
certain data "locked" on server side and actually never let the client
developer persist a full dataset copy with them. This .NET wrapper was
supposed to serve as an additional layer of protection between MGE API and
potential 3rd party APIs/implementations. But it's purpose is not
restrictive in nature, it would also enable MGE administrators create and
modify maps/layers/etc. apart from external solutions depending on it.
I'm currently working on exposing my .NET wrapper's methods to PHP users via
COM interop. Present PHP's function for direct connecting to .NET objects is
not working as expected.
As you may already guessed what's it all about - it's a city GIS used by
dozens of both municipal and infrastructure departments regionwide.
Regards,
Maksim Sestic
Kenneth, GEOGRAF A/S wrote:
> :D yes, that would be one way of coping with it.
> If you are up to the task, you can compile the mapguide server on your
> own machine.
> After compilation, it will create the .cs files required for the wrapper.
> You can modify those to work as you want, but be aware that you will
> need to keep your modifications up to date yourself.
> I am working on an alternate API, that uses Xml serialization to load
> and save the objects, but its still needs some work.
> Regards, Kenneth, GEOGRAF A/S
> Maksim Sestic skrev:
>> Hi Kenneth,
>> Thanks for the tip, it saved me hours of trying. This also means that we
>> need to write our own .NET wrappers over existing .NET wrappers to
>> include
>> proper object de/serialization... :-)
>> Regards,
>> Maksim Sestic
>>> Yes, you are missing a few key pieces of information.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/MgByteReader-and-XmlSerializer-question-tf4587994s16610.html#a13150828
