[mapguide-users] Intermittent failure to request features
simon hope
simonh at geobiz.co.nz
Sun Oct 14 20:33:23 EDT 2007
I've created a service to request features from ArcSDE via the Mapguide .Net
web API and I am experiencing an issue intermittently when a request is
made. Sometimes the request is successful sometime it fails with the
following error:
Error: An unclassified exception occurred.
StackTrace:
- MgFeatureServiceHandler.ProcessOperation line 83 file
c:\build_bond_area\mapguide_open_source_v1.2\build_18.1\mgdev\server\src\services\feature\FeatureServiceHandler.cpp
- MgOpSelectFeatures.Execute line 112 file
c:\build_bond_area\mapguide_open_source_v1.2\build_18.1\mgdev\server\src\services\feature\OpSelectFeatures.cpp
- MgServiceOperation.EndExecution line 532 file
c:\build_bond_area\mapguide_open_source_v1.2\build_18.1\mgdev\server\src\common\base\ServiceOperation.cpp
- MgServerFeatureReader.Serialize line 615 file
c:\build_bond_area\mapguide_open_source_v1.2\build_18.1\mgdev\server\src\services\feature\ServerFeatureReader.cpp
- MgServerGetFeatures.GetFeatures line 101 file
c:\build_bond_area\mapguide_open_source_v1.2\build_18.1\mgdev\server\src\services\feature\ServerGetFeatures.cpp
I've also tested making the same request from the web tier tests and I get
similar results. I am using MapGuide OS 1.2 together with the
MapGuideDotNetApi.dll and ArcSDE 9.2 (with the corresponding provider).
I've made a couple of changes to my server config. Here are the details:
GENERAL
ConnectionTimeout = 5
ConnectionTimerInterval = 5
DefaultMessageLocale =en
DisplayName =
FdoPath =C:\Program
Files\MapGuideOpenSource\Server\Bin\FDO\
LicenseServerPath = @localhost
Locale =
LogsDelimiter = \t
LogsPath =C:\Program
Files\MapGuideOpenSource\Server\Logs\
MachineIp = 127.0.0.1
MaxLogFileSize = 1024
MaxLogFileSizeEnabled = 0
ResourcesPath =C:\Program
Files\MapGuideOpenSource\Server\Resources\
SerialNumber =
ServiceRegistrationTimerInterval = 60
TcpIpMtu = 1460
TempPath =C:\Program
Files\MapGuideOpenSource\Server\Temp\
WfsDocumentPath =C:\Program
Files\MapGuideOpenSource\Server\Wfs\
WmsDocumentPath =C:\Program
Files\MapGuideOpenSource\Server\Wms\
FEATURE SERVICE
CacheSize = 100
CacheTimeLimit = 86400
CacheTimerInterval = 3600
DataCacheSize = 100
DataConnectionPoolEnabled = 1
DataConnectionPoolExcludedProviders= OSGeo.SDF,OSGeo.SHP
DataConnectionPoolSize = 50
DataConnectionPoolSizeCustom =
DataConnectionTimeout = 5
DataConnectionTimerInterval = 5
JoinQueryBatchSize = 100
Could anyone shed any light on the details of the error message, or perhaps
other on the list have had similar problems?
Cheers
Simon
View this message in context: http://www.nabble.com/Intermittent-failure-to-request-features-tf4623901s16610.html#a13205083
