[mapguide-users] Intermittent failure to request features
simon hope simonh at geobiz.co.nz
Sun Oct 14 23:39:41 EDT 2007
Just a quick update, I made the following changes to the serverconfig:
under  F E A T U R E  S E R V I C E
DataConnectionTimeout              = 1
DataConnectionTimerInterval        = 1
under  G E N E R A L
and i built a stress tester and sent a request every second and didn't get a
failure...so good show.
Simon
simon hope wrote:
> Hi,
> I've created a service to request features from ArcSDE via the Mapguide
> .Net web API and I am experiencing an issue intermittently when a request
> is made. Sometimes the request is successful sometime it fails with the
> following error:
>  Error: An unclassified exception occurred.
>  StackTrace:
>   - MgFeatureServiceHandler.ProcessOperation line 83 file
> c:\build_bond_area\mapguide_open_source_v1.2\build_18.1\mgdev\server\src\services\feature\FeatureServiceHandler.cpp
>   - MgOpSelectFeatures.Execute line 112 file
> c:\build_bond_area\mapguide_open_source_v1.2\build_18.1\mgdev\server\src\services\feature\OpSelectFeatures.cpp
>   - MgServiceOperation.EndExecution line 532 file
> c:\build_bond_area\mapguide_open_source_v1.2\build_18.1\mgdev\server\src\common\base\ServiceOperation.cpp
>   - MgServerFeatureReader.Serialize line 615 file
> c:\build_bond_area\mapguide_open_source_v1.2\build_18.1\mgdev\server\src\services\feature\ServerFeatureReader.cpp
>   - MgServerGetFeatures.GetFeatures line 101 file
> c:\build_bond_area\mapguide_open_source_v1.2\build_18.1\mgdev\server\src\services\feature\ServerGetFeatures.cpp
> I've also tested making the same request from the web tier tests and I get
> similar results. I am using MapGuide OS 1.2 together with the
> MapGuideDotNetApi.dll and ArcSDE 9.2 (with the corresponding provider).
> I've made a couple of changes to my server config. Here are the details:
> GENERAL
> ConnectionTimeout                  = 5
> ConnectionTimerInterval            = 5
> DefaultMessageLocale               =en
> DisplayName                        =
> FdoPath                            =C:\Program
> Files\MapGuideOpenSource\Server\Bin\FDO\
> LicenseServerPath                  = @localhost
> Locale                             =
> LogsDelimiter                      = \t
> LogsPath                           =C:\Program
> Files\MapGuideOpenSource\Server\Logs\
> MachineIp                          = 127.0.0.1
> MaxLogFileSize                     = 1024
> MaxLogFileSizeEnabled              = 0
> ResourcesPath                      =C:\Program
> Files\MapGuideOpenSource\Server\Resources\
> SerialNumber                       =
> ServiceRegistrationTimerInterval   = 60
> TcpIpMtu                           = 1460
> TempPath                           =C:\Program
> Files\MapGuideOpenSource\Server\Temp\
> WfsDocumentPath                    =C:\Program
> Files\MapGuideOpenSource\Server\Wfs\
> WmsDocumentPath                    =C:\Program
> Files\MapGuideOpenSource\Server\Wms\
> FEATURE SERVICE
> CacheSize                          = 100
> CacheTimeLimit                     = 86400
> CacheTimerInterval                 = 3600
> DataCacheSize                      = 100
> DataConnectionPoolEnabled          = 1
> DataConnectionPoolExcludedProviders= OSGeo.SDF,OSGeo.SHP
> DataConnectionPoolSize             = 50
> DataConnectionPoolSizeCustom       =
> DataConnectionTimeout              = 5
> DataConnectionTimerInterval        = 5
> JoinQueryBatchSize                 = 100
> Could anyone shed any light on the details of the error message, or
> perhaps other on the list have had similar problems?
> Cheers
> Simon
View this message in context: http://www.nabble.com/Intermittent-failure-to-request-features-tf4623901s16610.html#a13206240
