[mapguide-users] How to get programmatically a point coordinates?
Kenneth, GEOGRAF A/S ks at geograf.dk
Mon Oct 15 06:09:28 EDT 2007
1. There exists a JavaScript function called DigitzePoint(callback);
Look in the manual for details.
2. If you want to do it runtime, look in the manual for an example.
If you just want a permanent layer, get a hold of MapGuide Studio.
To get PostGIS data, download and install the PostGIS provider.
3. What do you want to integrate it with?
Links are usually created with the <a href="..."></a> tags, but I don't
think thats what you mean.
Regards, Kenneth, GEOGRAF A/S
dorra2007 skrev:
> Hello all,
> I am beginner in Mapguide and I would like to develop a geolocalization
> application.
> My problem is :
> How to create a JSP/JS file which allow a user to put a marker on the map
> when he clics on it.
> I think that the first step is to get the point coordinates which is the key
> of the probelm, then store them in a postgis database (which is relatively
> simple to do), after that create a layer of points (from the postgis
> database) and display the symbol in the appropriate place (difficult task).
> If I summarize the problem:
> 1-How to get the coordinate system of a point by listenning the mouse event
> (after a clic) (using JSP/JS)
> 2-How to create a layer (from a postgis database) and display it (using
> JSP/JS always).
> 3-How to integrate my JSP/JS file in my application (create links between
> files)
> It's very important for me to resolve this problem.
> If you have any suggestion, it's welcome. Thank you very much for your help.
