[mapguide-users] Mapguide and Oracle: The remote server returned
an error: (559) MgFdoException
Zac Spitzer
zac.spitzer at gmail.com
Wed Oct 17 12:07:22 EDT 2007
Be aware that there are some issues with layer filters not working
with King.Oracle
I'm not 100% sure but 0.7.3 works better with the oracle instant
client from http://www.sl-king.com/fdooracle than the full oracle
client, there was some issues with a memory leak.
At some point Harris was going to open source King.Oracle
Here is a working feature source example.
<?xml version="1.0" encoding="ISO-8859-1"?>
<FeatureSource xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:xsd="http://www.w3.org/2001/XMLSchema"
xsi:noNamespaceSchemaLocation="FeatureSource-1.0.0.xsd">
<Provider>King.Oracle</Provider>
<Parameter>
<Name>Username</Name>
<Value>PSMA_AUG_07</Value>
</Parameter>
<Parameter>
<Name>Password</Name>
<Value>moenkey77455secret</Value>
</Parameter>
<Parameter>
<Name>Service</Name>
<Value>ZAC</Value>
</Parameter>
<Parameter>
<Name>OracleSchema</Name>
</Parameter>
</FeatureSource>
On 10/18/05, CDM - Federica De Martin <tecnico at gpingegneria.it> wrote:
> Hi!
> I have got some problems loading data with MapGuide Open Source. First of
> all I have WindowsXP and I'm using MapGuide Studio Preview version and I try
> to connect to Oracle database.
> If I try to use:
> "OSGEO Fdo Provider for SHP" everything's ok (Connection Successfull...);
> "OSGEO Fdo Provider for Raster" Connection is Successfull but then I cannot
> view the data in a layer or map preview;
> "OSGEO Fdo Provider for ODBC" I cannot connect to any data type (not only
> Oracle) and I always get:
> System.Net.WebException: The remote server returned an error: (559)
> MgFdoException.
> in
> Autodesk.MapGuide.Studio.Site.Comm.RequestManager.ExecutePendingGetRequestToString(Operation
> operation)
> in
> Autodesk.MapGuide.Studio.Site.Comm.RequestManager.TestConnection(String
> resourceId, String provider, String connectionString)
> in
> Autodesk.MapGuide.Studio.Site.FeatureSourceInfo.TestConnection()
> in
> Autodesk.MapGuide.Studio.UI.FeatureSourceEditors.TestConnectionControl.buttonTestConnection_Click(Object
> sender, EventArgs e)
> I've controlled in
> c:\programmi\MapGuideOpenSource\Server\Bin\FDO\provider.xml
> and the ODBC provider is correctly listed.
> I get the same error if I try to connect with "King provider for Oracle".
> In my opinion it isn't a problem of parameters but I've tried so many
> combination that now I'm not still so sure... it would be also useful
> if someone can tell me how parameters had to be set. This is an example of
> mine:
> <FeatureSource
> <Provider>OSGeo.ODBC.3.2</Provider>
> <Parameter>
> <Name>UserId</Name>
> <Value>gis</Value>
> </Parameter>
> <Parameter>
> <Value>gis</Value>
> </Parameter>
> <Parameter>
> <Name>DataSourceName</Name>
> <Value>ubuntuXE</Value>
> </Parameter>
> <Parameter>
> <Name>ConnectionString</Name>
> <Value></Value>
> </Parameter>
> <Parameter>
> <Name>GenerateDefaultGeometryProperty</Name>
> <Value></Value>
> </Parameter>
> </FeatureSource>
> I hope someone has already faced this problem and can help me to make it
> work!
> Thank you all.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
http://zacster.blogspot.com/
+61 405 847 168 (aussie moible)
