[mapguide-users] Collapse layers and properties panes
Jim O'Leary
joleary.public at gmail.com
Thu Oct 18 13:11:08 EDT 2007
Is it possible to collapse the layers and properties pane programmatically? I
can set the InfoBand td width to 0px and set the InfoDiv div to display =
none with JavaScript, but the map itself moves to the left, it does not
expand to cover the entire map frame. Furthermore, when you pan or do other
viewer operations with the map this way, you soon get JavaScript errors,
indicating that the JavaScript code is looking for those collapsed TD/Divs.
Thanks
View this message in context: http://www.nabble.com/Collapse-layers-and-properties-panes-tf4648417s16610.html#a13279235
