[mapguide-users] MapGuide Automated Tiling Engine 1.2
Kori Maleski
kori.maleski at gmail.com
Tue Sep 25 23:33:59 EDT 2007
Thanks George.
Try running with the -l log switch and see if it spits out the error to the
log file.
I delay the requests by 50 milliseconds so as not to kill the mgserver
process. I may have to bump it up if this occurs regularly.
I have only been testing on Sheboygan, which may not be a good enough test
map.
Cheers,
Kori Maleski
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of George McLean
Sent: September 25, 2007 6:18 PM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] MapGuide Automated Tiling Engine 1.2
Kori,
The tiling engine rocks!
This will make a huge difference in the perception of Mapguide's
performance for my users.
I did have trouble running it on a XP box that is a development machine.
This machine has 2gb ram and a 3.4 Ghz pentium processor. In creating
the 5th of 7 tiling groups, the tiling engine appeared to hang after
1922 tiles in this 5th group. The CPU had very little activity and both
mgserver and fmtilingengine were not using any CPU or much memory. It
was hung on that tile for about an hour before I aborted. I did not have
any trouble running on a similar machine with Win 2003 server as the OS.
Thank you very much for this really useful tool!
George McLean
Kori Maleski wrote:
> Hi everyone,
> Websoft Developers is pleased to announce the availability of the new
> 1.2 version of our free MapGuide tiling utility.
> You may download the installation file from the following link:
> Http://www.websoftdev.com/download.cfm
> <http://www.websoftdev.com/download.cfm>
> This is a command line utility that can be accessed via a windows
> console window or executed via a batch file.
> Note:
> 1) The application will work on both MapGuide Open Source 1.2 and
> Autodesk MapGuide Enterprise 2008.
> 2) The application works on the Windows platform only, and will work
> with .NET, Java and PHP extensions having been installed.
> 3) Replace MapGuide Open DLLs/webconfig.ini with MapGuide Enterprise
> DLLs/webconfig.ini and reconfigure the Tiling Engine config for use
> with Enterprise.
> Please provide feedback for any bugs and application hangs, etc.
> Enjoy!
> __
> _ [http://www.websoftdev.com/] <http://www.websoftdev.com/>_
> **Kori Maleski**
> Senior Application Developer
> WEBSOFT DEVELOPERS, INC.
> P: (530) 759-8754 ext 114
> F: (530) 759-0923
> kori.maleski at websoftdev.com <mailto:kori.maleski at websoftdev.com>
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
> No virus found in this incoming message.
> Checked by AVG Free Edition.
> Version: 7.5.488 / Virus Database: 269.13.30/1030 - Release Date:
9/25/2007 8:02 AM
