[mapguide-users] RE: RE: RE: Layer Projection
emviado
emmanuelviado at yahoo.com
Sun Sep 30 08:51:49 EDT 2007
Thanks Traian. I'll look into it and try to create an appropriate WKT string
for palawan coordinate system.
regards,
emviado
Traian Stanev wrote:
> Hmmm. The only projected coordinate systems with the Luzon datum I see
> in the PROJ list are
> 25391,"Luzon 1911 / Philippines zone
> I",9001,4253,18171,9807,1,0,8801,0,9102,8802,117,9102,8805,0.99995,9201,
> 8806,500000,9001,8807,0,9001,,,,,,
> 25392,"Luzon 1911 / Philippines zone
> II",9001,4253,18172,9807,1,0,8801,0,9102,8802,119,9102,8805,0.99995,9201
> ,8806,500000,9001,8807,0,9001,,,,,,
> 25393,"Luzon 1911 / Philippines zone
> III",9001,4253,18173,9807,1,0,8801,0,9102,8802,121,9102,8805,0.99995,920
> 1,8806,500000,9001,8807,0,9001,,,,,,
> 25394,"Luzon 1911 / Philippines zone
> IV",9001,4253,18174,9807,1,0,8801,0,9102,8802,123,9102,8805,0.99995,9201
> 25395,"Luzon 1911 / Philippines zone
> V",9001,4253,18175,9807,1,0,8801,0,9102,8802,125,9102,8805,0.99995,9201,
> I can't find a pre-defined Zone 50 with your datum. So you may have to
> create your own WKT string for that coordinate system. Or, if all your
> data are using the same coordinate system, you can just try using an
> arbitrary XY coordinate system.
> Traian
>> -----Original Message-----
>> From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-
>> bounces at lists.osgeo.org] On Behalf Of emviado
>> Sent: Friday, September 28, 2007 1:27 AM
>> To: mapguide-users at lists.osgeo.org
>> Subject: [mapguide-users] RE: RE: Layer Projection
>> No .prj file but, I was just informed that the coordinate properties
>> are:
>> Projection: UTM Zone50N
>> Datum: Luzon 1911
>> Units: Decimal Degrees
>> Spheroid: Clarke Spheroid of 1866
>> emviado
>> > Does your SHP file have an associated .PRJ file?
>> > Traian
>> >> Sent: Thursday, September 27, 2007 11:05 AM
>> >> Subject: [mapguide-users] RE: Layer Projection
>> >> Thanks for the prompt help Traian. NAD 27 is the North American
>> Datum.
>> >> I
>> >> should have mentioned that the shapefile I want to import is in
>> >> Palawan,
>> >> Philippines.
>> >> emviado
>> >> > Look for a UTM projection that uses the NAD 27 datum. NAD 27 uses
>> > the
>> >> > Clarke ellipsoid. If the SHP file has an associated PRJ file, it
>> >> should be
>> >> > automatically recognized.
>> >> > Traian
>> >> > From: mapguide-users-bounces at lists.osgeo.org on behalf of
>> >> Emmanuel Viado
>> >> > Sent: Wed 9/26/2007 8:56 PM
>> >> > Cc:
>> >> > Subject: [mapguide-users] Layer Projection
>> >> > Hi,
>> >> > Just starting to use MGO 1.2. I want to import a shapefile in
>> > UTM
>> >> Zone
>> >> > 50, Clarke 1866 ellipsoid projection. What projection in MGO do I
>> > use
>> >> to
>> >> > bring in the file?
>> >> > Thanks,
>> >> > emviado
>> >> > _____
>> >> > Got a little couch potato?
>> >> > Check out fun summer activities for kids.
> <http://us.rd.yahoo.com/evt=48248/*http://search.yahoo.com/search?fr=on
>> >> i_on_mail&p=summer+activities+for+kids&cs=bz>
>> >> > _______________________________________________
>> >> > mapguide-users mailing list
>> >> > http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> >> View this message in context: http://www.nabble.com/Layer-
>> Projection-
>> >> tf4525784s16610.html#a12923153
>> >> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> View this message in context: http://www.nabble.com/Layer-Projection-
>> tf4525784s16610.html#a12934872
View this message in context: http://www.nabble.com/Layer-Projection-tf4525784s16610.html#a12965444
