[mapguide-users] Re: Fusion using SVN as stated in Directions (JavaScript Error Fusion is Undefined)
Rock Beans rockbeans at gmail.com
Thu Aug 14 11:03:01 EDT 2008
Here it is
http://lists.osgeo.org/pipermail/mapguide-users/2008-July/013652.html will
this be commited to Fusion SVN soon as well as the other fixes? Seems simple
enough. Give me access and I will do it :-)
The Rock
On Thu, Aug 14, 2008 at 9:14 AM, Rock Beans <rockbeans at gmail.com> wrote:
> I followed the instructions on
> http://lists.osgeo.org/pipermail/mapguide-users/2008-July/013637.html and
> I am not getting the viewer to come up anymore. Was there some major changes
> that would cause this or what id the fix? I assume I am missing some setting
> somewhere. Are there updated mapguide templates maybe since the default SVN
> copy only contains standard and you have to copy over the old. The checked
> out fusion directory is in the same location as before and the old files are
> in fusion_old just in case everything should be working right?
> The reason why I am even doing this is the Save Map function causes
> Javascript "Access Denied" errors. Is there any information on either of
> these topics please?
> Erro info: Error: OpenLayers.String.translate is not a function
> Source File:
> http://localhost/mapguide/fusion/templates/mapguide/slate/index.html...
> Line: 34
> Does this mean I need to add open layers or something or disable for
> MapGuide?
> The Rock
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080814/6430cc18/attachment.html
