[mapguide-users] Fusion using SVN as stated in
Directions (JavaScript Error Fusion is Undefined)
Andrew DeMerchant
andrew.demerchant at gemtec.ca
Thu Aug 14 10:53:39 EDT 2008
Keep reading that thread - you need to modify the templates (each
index.html file) to get them to work with the newer Fusion....
Andrew
Rock Beans wrote:
> I followed the instructions on
> http://lists.osgeo.org/pipermail/mapguide-users/2008-July/013637.html
> and I am not getting the viewer to come up anymore. Was there some
> major changes that would cause this or what id the fix? I assume I am
> missing some setting somewhere. Are there updated mapguide templates
> maybe since the default SVN copy only contains standard and you have
> to copy over the old. The checked out fusion directory is in the same
> location as before and the old files are in fusion_old just in case
> everything should be working right?
> The reason why I am even doing this is the Save Map function causes
> Javascript "Access Denied" errors. Is there any information on either
> of these topics please?
> Erro info: Error: OpenLayers.String.translate is not a function
> Source File:
> http://localhost/mapguide/fusion/templates/mapguide/slate/index.html...
> Line: 34
> Does this mean I need to add open layers or something or disable for
> MapGuide?
> The Rock
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
*Andrew DeMerchant*
*Computer Technologist*
ph.1-877-2GEMTEC x.163
fax 506-453-9470
/GEMTEC Limited <http://www.gemtec.ca>
/191 Doak Road
Fredericton, NB, Canada
E3C 2E6
Skipped content of type multipart/related
