[mapguide-users] mapviewerphp-error in legend.phpfile(BuildClientSideTree)
Jason Birch Jason.Birch at nanaimo.ca
Fri Feb 8 04:18:11 EST 2008
Could you please enter this defect, along with the version of MapGuide OS you are using, etc, in our Trac instance?
http://trac.osgeo.org/mapguide/wiki/SubmitTicket
To confirm, this problem appears to still be present in trunk:
http://trac.osgeo.org/mapguide/browser/trunk/MgDev/Web/src/mapviewerphp/legend.php#l89
I believe that the fix is to either pass a null for the last parameter, or to change the function signature to give the last parameter a default value of null.
Thanks,
Jason
Subject: [mapguide-users] mapviewerphp-error in legend.phpfile(BuildClientSideTree)
Hi All,
               I think there is error in the legend.php file inside the mapviewerphp Folder--
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080208/9e9ef014/attachment.bin
