[mapguide-users] FDO 3.3 broke SDF files
Zac Spitzer
zac.spitzer at gmail.com
Wed Feb 13 22:23:42 EST 2008
I have seen the same problem, there is an existing ticket which was
just resolved
http://trac.osgeo.org/mapguide/ticket/424
z
On Feb 14, 2008 5:52 AM, Jason Birch <Jason.Birch at nanaimo.ca> wrote:
> I haven't seen this problem myself, though others have noted problems
> with selection. Here's my semi-form letter for issue submission :)
> The best way to ensure that this problem is addressed by a developer at
> some point (if you are unable to fix it yourself - patches welcome)
> would be to create a ticket in our Trac system:
> http://trac.osgeo.org/mapguide/wiki/SubmitTicket
> A good ticket is one which is quickly and easily reproducible by the
> developer. Please ensure that you include:
> - A complete description of your problem, including versions of the
> software, operating system, and configuration (ie. Apache+PHP, etc) that
> you are using
> - A reduced-set package of the data that you are experiencing the
> problem with (in this case, MGP of your data source, layer, map). If it
> is too large for Trac, indicate that you are willing to provide the
> data, or place it on an external server and link to it
> - A script of steps that the developer can follow to reproduce the
> problem you are seeing
> Thanks!
> Jason
> -----Original Message-----
> From: J Manafi
> Subject: [mapguide-users] FDO 3.3 broke SDF files
> the layers give an error stating "Resource
> ID does not refer to a valid feature source." This only happens for
> three of
> our layers; all the rest seem to provide valid feature data. If I do not
> delete the invalid layers from our map, when they are visible, I get the
> following error message returned in FireBug for the QUERYMAPFEATURES
> operation: Invalid argument(s): [1] = "-1" The value is invalid because
> it is too small.
> Assumingly unrelated to this problem, I am unable to select valid layers
> on
> the map that should be selectable; if I drag and highlight a point
> object,
> the status bar does not update with any features selected, and I am
> returned
> another error message for Query.php in FireBug
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer -
http://zacster.blogspot.com (My Blog)
+61 405 847 168
