[mapguide-users] Polygon labels - fusion problems
Paul Spencer
pagameba at gmail.com
Mon Feb 18 11:04:20 EST 2008
Traian,
my understanding was that I should be using GetMapImage for drawing
the map and GetVisibleMapExtent/GetDynamicMapOverlay for the
selection. And in fact, I think Trevor modified GetDynamicMapOverlay
to allow rendering just the selection.
From what you said below, it now appears that I should be using
GetVisibleMapExtent/GetDynamicMapOverlay for rendering map draws.
Note that this is problematic for OpenLayers because it currently uses
a synchronous AJAX call to GetVisibleMapExtent which is not desirable
and will require a rework of the MapGuide support in OpenLayers to
allow this to be done asynchronously.
Is there any reason why the two operations would be implemented
differently? Is one more correct than the other?
Cheers
Paul
On 15-Feb-08, at 6:20 PM, Jason Birch wrote:
> Traian, Paul,
> I observed considerable performance degradation between the old
> version
> of Fusion (pre-MGOS) that used GetDynamicMapOverlay instead of GetMap.
> This was with my Cemetery map data that has the nasty buffered roads
> layer. Sheboygan seemed to be fairly quick regardless.
> I'm wondering if this difference (clipping off) could be the
> culprit? I
> don't see the same performance decrease in the AJAX viewer for this
> map.
> I discussed this with Paul earlier, and think I was supposed to
> submit a
> bug report, but wasn't able to quickly put together a reproducible
> error
> report and it slipped my mind (doh!).
> Jason
> -----Original Message-----
> From: Traian Stanev
> Subject: RE: [mapguide-users] Polygon labels - fusion problems
> I think it could be that Fusion uses a RenderMap API which uses
> viewport
> clipping turned off (resulting in labels always being at the true
> centroid of polygons) while the MG ajax viewer uses
> RenderDynamicOverlay, which has viewport clipping turned on, resulting
> in polygons being labeled at the centroid of the clipped region.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Paul Spencer
CTO, DM Solutions Group Inc
http://www.dmsolutions.ca/
