[mapguide-users] InitializeWebTier
Jackie Ng jackie.ng at aecsystems.com.au
Thu Feb 28 03:24:51 EST 2008
Did you create the appropriate virtual directory in IIS that maps to where
that folder is, and is it configured as an application?
- Jackie
swetha1 wrote:
> Well i have copied all the folders available in dotnetviewersample in a
> folder created in www....Then opened the same folder in visual
> studio....Then as you said have changed the webserver..... Now it is
> unable to find the utilityfunctions.aspx.....It says that failed to map
> Regards
> Swetha
> Jackie Ng wrote:
>> You're gonna have to be more specific with the error message.
>> - Jackie
>> swetha1 wrote:
>>> Hi,
>>> It is now giving me an error saying "failed to map
>>> "utilityfunctions.aspx".....It is in the same folder which is
>>> created.....Dont know why it is unable to find it?
View this message in context: http://www.nabble.com/InitializeWebTier-tp15729918s16610p15731704.html
