[mapguide-users] InitializeWebTier
swetha1 swetha.sub at gmail.com
Thu Feb 28 03:27:27 EST 2008
Yes i have configured and it is also as an application
Swetha
Jackie Ng wrote:
> Did you create the appropriate virtual directory in IIS that maps to where
> that folder is, and is it configured as an application?
> - Jackie
> swetha1 wrote:
>> Well i have copied all the folders available in dotnetviewersample in a
>> folder created in www....Then opened the same folder in visual
>> studio....Then as you said have changed the webserver..... Now it is
>> unable to find the utilityfunctions.aspx.....It says that failed to map
>> Regards
>> Swetha
>> Jackie Ng wrote:
>>> You're gonna have to be more specific with the error message.
>>> - Jackie
>>> swetha1 wrote:
>>>> Hi,
>>>> It is now giving me an error saying "failed to map
>>>> "utilityfunctions.aspx".....It is in the same folder which is
>>>> created.....Dont know why it is unable to find it?
View this message in context: http://www.nabble.com/InitializeWebTier-tp15729918s16610p15731706.html
