[mapguide-users] New KML FDO provider
Haris Kurtagic haris at sl-king.com
Tue Jul 29 11:02:54 EDT 2008
I am working on new King.KML FDO provider for KML 2.2. If accepted it
will be part of Open Source providers.
It is very early stage in development but I wanted to share it very
soon. There is lot of options and getting more opinions on it can be
useful.
Right now King.KML provider  allows you to:
-          display KML in MapGuide , AutoCAD Map. It will display
Placemark name, description and attributes (ExtendedData from KML)
-          you can select features, run queries against KML, etc..
-          allow insert and update of geometries and attributes in KML (
you can use AutoCAD Map to try it too)
-          you can use Fdo2Fdo to copy existing data (shp,sdf, oracle,
any fdo...) to create new KML
Many things are missing right now , I will be happy to get info from you
too.
I am working on: how to setup which FDO properties will be used for
placemark name description, how to set style of created placemark etc..
You can get  provider here: http://www.sl-king.com/fdokml/fdokml.html
and Fdo2Fdo with KML support:
http://www.sl-king.com/fdo2fdo/fdo2fdo.html
Haris
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080729/ccf37186/attachment.html
