[mapguide-users] Problem Loading Shape file
sweet_reshu
7486ster at gmail.com
Mon Jun 2 01:59:38 EDT 2008
I TRIED IT ON WINDOW IT IS WORKING PROPERLY
select exact co-ordination system ,refer sheboygan examples and enter
currect co-ordinations of your shp files
Rahul sharma wrote:
> Hi
> I am loading shapefile of B.C coastal line using MAPGUIDE STUDIO and I get
> the following error message my data is in BC Albers NAD 83
> The coordinate system is invalid.
> PROJCS["PCS_Albers",GEOGCS["GCS_North_American_1983",DATUM["D_North_American
> _1983",SPHEROID["GRS_1980",6378137.0,298.257222101]],PRIMEM["Greenwich",0.0]
> ,UNIT["Degree",0.0174532925199433]],PROJECTION["Albers"],PARAMETER["False_Ea
> sting",1000000.0],PARAMETER["False_Northing",0.0],PARAMETER["Central_Meridia
> n",-126.0],PARAMETER["Standard_Parallel_1",50.0],PARAMETER["Standard_Paralle
> l_2",58.5],PARAMETER["Latitude_Of_Origin",45.0],UNIT["Meter",1.0]]
> Could not create coordinate system forward transformation with specified
> coordinate systems. Exception occurred in method
> MgCoordinateSystem.MgCoordinateSystem at line 77 in file
> c:\build_bond_area\mapguide_open_source_v1.2\build_18.1\mgdev\common\geometr
> y\CoordinateSystem/CoordinateSystem.cpp
> I have tried changing the projection , I come to know that MapGuide Studio
> does not have BC Albers projections so I downloaded a file and put the
> projections there but still get the same error message
> I would be glad if some one can help me
> Attach is the eimage whee i select the projections
> http://www.nabble.com/file/p15361735/untitled.jpeg
View this message in context: http://www.nabble.com/Problem-Loading-Shape-file-tp15361735p17594465.html
