[mapguide-users] FM Tiling Engine on MGOS 2.0.1
Jackie C. Ng
jumpinjackie at gmail.com
Thu Jun 5 10:09:32 EDT 2008
Try copying all the dlls from the mapviewernet\bin directory and overwrite
the ones installed by the Tiling Engine and see if that helps.
- Jackie
max_samart wrote:
> Hi All,
> I am using PHP+Apache+Windows Server 2003 ,and i would like
> to enquire that whether FM Tiling Engine supports MGOS 2.0.1 on the above
> configuration and if so then what kind of dll files should be copied
> fromMapGuideOpenSource2.0\WebServerExtension\www into the Websoft
> Developers\FacilitiesMap Tiling Engine Folder, I already configured the
> FMTilingEngine.exe.config file as well as replaced the webconfig.ini file.
> Thks
> Max !
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
http://themapguyde.blogspot.com
http://www.linkedin.com/in/jackieng
View this message in context: http://www.nabble.com/FM-Tiling-Engine-on-MGOS-2.0.1-tp17663298p17670722.html
