[mapguide-users] ecw on mgos-2.0.1
ary sucaya ary.sucaya at yahoo.com
Thu Jun 12 00:28:26 EDT 2008
Slash or backslash is not matter but space is really matter. If you have a folder with space, then you will see a simptom as i describe before..
----- Original Message ----
To: MapGuide Users Mail List <mapguide-users at lists.osgeo.org>
Sent: Thursday, June 12, 2008 4:47:18 AM
Subject: Re: [mapguide-users] ecw on mgos-2.0.1
Hi
I am using D:\Raster\Data and its wroking without any problem for ecw files,can somebody confirm about using D:\Raster\Data  or D:/Raster/Data
Max !!
To: mapguide-users at lists.osgeo.org
Sent: Wednesday, June 11, 2008 10:56:30 PM
When creating your raster data connections, use "/" instead of "\" in your
paths.
C:/Program
Files/MapGuideOpenSource2.0/WebServerExtensions/www/mapcatalogue/data/world.ecw
instead of
C:\Program
Files\MapGuideOpenSource2.0\WebServerExtensions\www\mapcatalogue\data/world.ecw
it may also be a problem with the space in "Program Files". You may need to
place your ecw files in a different location that does not have spaces i the
path.
hope ths helps
ary sucaya wrote:
> Hello group,
> Did someone succesfully open ecw file on mgos 2.0.1? I went through
> http://trac.osgeo.org/fdo/wiki/FdoGdalNotes#Documentation but i couldn't
> get it work. i turn on rasters debugging and here is the result:
> ECW: NCScbmOpenFileView(C:\Program
> Files\MapGuideOpenSource2.0\WebServerExtensions\www\mapcatalogue\data/world.ecw):
> eErr = 0
> ECW: FileInfo: SizeXY=4320,2160 Bands=3
>        OriginXY=-180,90  CellIncrementXY=0.0833333,-0.0833333
> ECW: projection=GEODETIC, datum=WGS84
> GDAL: GDALOpen(C:\Program
> succeeds as ECW.
> GDAL: GDALClose(C:\Program
> I tried to change the coordinate system into LL84 (LL84) or LL84-WP
> (LL84-WP) but still unlucky.. Someone know how to solve this?
> Regards,
> Ary Sucaya
> mapguide-users mailing list
View this message in context: http://www.nabble.com/ecw-on-mgos-2.0.1-tp17778662p17781203.html
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080611/1f5c84bd/attachment.html
