[mapguide-users] Feature Joins
Dave Wilson dave.wilson at autodesk.com
Mon Mar 10 11:07:42 EDT 2008
Are you expecting 2 features to be rendered in the map? Are you expecting to see 2 property sets in the AJAX Viewer? It sounds like the former? I'm not sure anyone has requested multiple features to appear as a result of a 1 to many join. Users have wanted to see the multiple properties associated with the join. The information is available via the API.
As well with the new Flexible Web Layouts the multiple properties are available in the selection pane.
Regards,
Dave
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Chris Tallman
Sent: Monday, March 10, 2008 7:28 AM
To: MapGuide Users Mail List
Subject: [mapguide-users] Feature Joins
Morning all.
Is anyone seeing issues with joins, using one-to-many?  I have an sdf feature joined to a MSAccess file.  I'm only seeing the first join per feature, the second, third and on are ignored.
I'm on MGOS 1.2 IIS 6 .net install.
I've created the same join in autocad and I don't have a problem.
More detail:  I have a sdf feature source that is buildings.  My database has a list of majors.  Both have a Building ID.  One id per building. Multiple majors per building.  I'm trying to create layers based on the join that displays buildings based on majors.  If a building has multiple majors it only shows up once and it seems to only be the first match it comes across.  So I guess it's acting more like a one-to-one join.
I hope this enough explanation someone will be able to help me out.  If not let me know and I can try and explain more.
Chris Tallman
Director of GIS Operations
Innovation Mapping, LLC
260-356-9074
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080310/61b51000/attachment.html
