[mapguide-users] Feature Joins
Chris Tallman
ctallman at innomap.com
Tue Mar 11 07:18:22 EDT 2008
I'm doing an Outer 1-Many Join. It's the Many that seems to be broken.
Only the first match is joined. I would guess this may have been one of
the issues in 1.2.
Right now 2.0 isn't really an option for us. I have been testing, but
we're not ready to move over to it. I have tried to make this same join
in 2.0 but the test machine either isn't big enough or the join really
consumes alot of resources.
Chris
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Bruce
Dechant
Sent: Monday, March 10, 2008 11:42 AM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] Feature Joins
Chris,
MGOS 1.2 did have some join issues and I believe you might be
encountering one of them. Are you doing an inner or outer join?
With MGOS 2.0 I have joined SDFs with Access many times in the following
cases:
Inner 1-1
Inner 1-Many
Outer 1-1
Outer 1-Many
The above worked for my use cases with MGOS 2.0. Would you be able to
try MGOS 2.0?
Thanks,
Bruce
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Chris
Tallman
Sent: Monday, March 10, 2008 7:28 AM
Subject: [mapguide-users] Feature Joins
Morning all.
Is anyone seeing issues with joins, using one-to-many? I have an sdf
feature joined to a MSAccess file. I'm only seeing the first join per
feature, the second, third and on are ignored.
I'm on MGOS 1.2 IIS 6 .net install.
I've created the same join in autocad and I don't have a problem.
More detail: I have a sdf feature source that is buildings. My
database has a list of majors. Both have a Building ID. One id per
building. Multiple majors per building. I'm trying to create layers
based on the join that displays buildings based on majors. If a
building has multiple majors it only shows up once and it seems to only
be the first match it comes across. So I guess it's acting more like a
one-to-one join.
I hope this enough explanation someone will be able to help me out. If
not let me know and I can try and explain more.
Chris Tallman
Director of GIS Operations
Innovation Mapping, LLC
260-356-9074
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080311/0af6d36b/attachment.html
