[mapguide-users] Problem with MG 2.0 installation on w2k3
Jackie Ng jackie.ng at aecsystems.com.au
Mon Mar 17 22:07:15 EDT 2008
Are you able to run MapGuide Server interactively (ie. not as a service)
without problems?
- Jackie
NorTrond wrote:
> Hi,
> I have tried to install MG 2.0 on 2 different Windows 2003 SP2 machines
> with the same problem. The installation process goes well, but when I look
> in the service control panel the "MapGuide Server V2.0" service is not
> running. When I try to start it, it dies immediately.  I looked in the
> system event log and found the following entry there : "Faulting
> application mgserver.exe, version 2.0.0.2308, faulting module msvcr80.dll,
> version 8.0.50727.762, fault address 0x000046b4." Is there a special trick
> to get this working ?. I'm using the default setting on all the
> installation parameters , with the .NET and IIS options chosen.
> Br
> Trond Tunheim, CellVision AS
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/Problem-with-MG-2.0-installation-on-w2k3-tp16095052s16610p16112216.html
