[mapguide-users] Problem with MG 2.0 installation on w2k3
Trond A. Tunheim trond.tunheim at cellvision.com
Tue Mar 18 03:28:15 EDT 2008
Nope when I run the mgserver.exe with the run parameter it returns the following :
Running the server interactively as an application instead of as a service.
(3032) Failed to retrieve message for "MgInvalidArgumentException".
        [1] = "const string&"
Failed to retrieve message for "MgInvalidStringConversion".
Exception occurred in method MgUtil.WideCharToMultiByte at line 297 in file d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\common\foundation\System/Util.cpp
(3032) Failed to retrieve message for "MgConnectionNotOpenException".
Exception occurred in method MgSiteConnection.GetCurrentUserInfo at line 382 in file d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\common\mapguidecommon\System/UserInformation.cpp
This application has requested the Runtime to terminate it in an unusual way.
Please contact the application's support team for more information.
Any clue of what is causing this ?
/Trond
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
Sent: 18. mars 2008 03:07
To: mapguide-users at lists.osgeo.org
Subject: Re: [mapguide-users] Problem with MG 2.0 installation on w2k3
Are you able to run MapGuide Server interactively (ie. not as a service)
without problems?
- Jackie
NorTrond wrote:
> Hi,
> I have tried to install MG 2.0 on 2 different Windows 2003 SP2 machines
> with the same problem. The installation process goes well, but when I look
> in the service control panel the "MapGuide Server V2.0" service is not
> running. When I try to start it, it dies immediately.  I looked in the
> system event log and found the following entry there : "Faulting
> application mgserver.exe, version 2.0.0.2308, faulting module msvcr80.dll,
> version 8.0.50727.762, fault address 0x000046b4." Is there a special trick
> to get this working ?. I'm using the default setting on all the
> installation parameters , with the .NET and IIS options chosen.
> Br
> Trond Tunheim, CellVision AS
> mapguide-users mailing list
View this message in context: http://www.nabble.com/Problem-with-MG-2.0-installation-on-w2k3-tp16095052s16610p16112216.html
