[mapguide-users] 1.2 to 2.0 Development
Kenneth, GEOGRAF A/S
ks at geograf.dk
Thu Mar 27 17:19:23 EDT 2008
The stream error usually means that the client binaries are not the same
version as the server binaries (They serialize/deserialize different).
Are you sure you are using the correct binaries, and not a cached old
version?
Regards, Kenneth, GEOGRAF A/S
Jason Birch skrev:
> The coordinate system stuff is an advertised change:
> http://trac.osgeo.org/mapguide/wiki/Release/2.0/Notes
> http://trac.osgeo.org/mapguide/wiki/MapGuideRfc35
> I wonder if the other problem you're seeing is a bug? The Java API is
> probably the least used
> Jason
> *From:* Rock Beans
> *Subject:* [mapguide-users] 1.2 to 2.0 Development
> I have noticed many things broken with our development code primarily
> using the Java based MapGuide API. Things like MGCordsys and simple
> calls like getting column listings from a layer (stream error) are now
> all broken. What happened to being backwards compatible? Are all
> developers that sunk time and effort into every version going to get
> complaints and calls from clients every version change? I am sure
> there was good reason to change things up for functionality or speed
> but was there now way to reference the new objects from the old
> objects? Is there some documentation on what to watch out for as you
> upgrade, as far as API development goes?
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080327/615c6e37/attachment.html
