[mapguide-users] [ZS1] RE: MG2.0 install with other webapplications
Xetec xetec at hotmail.com
Mon May 5 17:50:28 EDT 2008
First of all, thanks for the help.  Here is where we currently are at:
We got the application pool setup and the mapguide server on a seperate
website location, other than default.  We've setup a host header in DNS to
point to the server.  So we now can connect to the server via Studio or
AutoCAD map.
However something is not right.  I don't seem to be able to login to the
admin webpage.  It comes up but when I enter the Administrator user name and
password, it jumps me back to the login screen.  I can keep entering in the
admin info but it's an endless loop.  Any ideas to try?
Thanks,
-Bob
JasonBirch wrote:
> In addition to what Kenneth went over for the application pool, you can
> migrate MapGuide to a different website fairly easily.  You shouldn't have
> to configure anything in the mapguide virtual directory before exporting
> it.  I'm assuming IIS6 (Windows 2003) here:
> - Open the "Default Website", right-click on the "mapguide" virtual
> directory, select "All Tasks", and then Save Configuration to a File
> - Right-click on the "Web Sites" folder, choose "New" and then "Web Site".
> When setting up this new website, you have to either need have a second IP
> address on your server or you need to configure your site to listen to a
> specific host header (that needs to be set up in DNS first).  The latter
> is generally a good idea anyway...  I typically leave my Default Website
> listening on 127.0.0.1/localhost (so I can access it from the server if I
> need to) and create new sites for other content.
> - Right-click on the new website and choose "New" and then "Virtual
> Directory (from file)".  Read the XML document that you created earlier,
> and choose to import the "mapguide" virtual directory (the others will
> come along for the ride).
> If you haven't already, configure the "mapguide" virtual directory to use
> its own application pool.  You may wish to make your entire new website
> use this application pool instead of just the mapguide directory.
> There are some good white papers from Autodesk on how to configure
> MapGuide securely, and how to tweak performance (it's all in the data):
> http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=7798553
> <http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=7798553>
> You can do just about anything with the directory structure that you want,
> but getting the ajax viewer or fusion to work properly with non-standard
> configurations can be a bit of a heroic effort.  Early versions of
> MapGuide made you set this all up manually though, and there are docs on
> manual setup around...  like this one:
> http://trac.osgeo.org/mapguide/wiki/MGOS2onVistaIIS7
> <http://trac.osgeo.org/mapguide/wiki/MGOS2onVistaIIS7>
> In general though, if you don't have much experience with IIS
> administration or have someone available who does, you may want to
> consider staying with the stock configuration.
> Jason
> Original message:
> You would mind explaining this process step by step?  I'm not an expert on
> getting multiple websites to work together.  So far I've had good success
> on
> our test server, but the main webapps server is where the challenge is.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/MG2.0-install-with-other-web-applications-tp16986233p17071443.html
